Precession angle per orbit of perhelion precession mercury
In summary, the conversation discusses the different equations related to the mercury precession angle per orbit and the excess angle per orbit. The speaker is questioning their own calculation and the intuition behind it, suggesting that the total angle should be less than 2pi + delta. The other person responds by explaining the approximation used for perihelion precession as a simple addition of angular velocities. They also mention the contributions of the two angular velocities, w0 and w1, to the real angular velocity, \omega, in one period T.
fakrudeen
Many derivations of mercury precession angle per orbit [tex]\Delta[/tex][tex]\Phi[/tex], equate this to extra angle per orbit [tex]\delta[/tex] in excess of [tex]2\pi[/tex]
that is [tex]\delta[/tex] = [tex]\Delta[/tex][tex]\Phi[/tex]
But I am getting this relation
[tex]\sqrt{4\pi\delta}[/tex]= [tex]\Delta[/tex][tex]\Phi[/tex]
from arc length of helix and circular orbit.
What am I doing wrong?
What is the intution for above approximation? Shouldn't the total angle be less than [tex]2\pi[/tex] + [tex]\Delta[/tex][tex]\Phi[/tex]
because planet takes short cut [analagous to hypotenuse length being less than sum of other two sides]
I was trying to approximate perihelion precession as helix and its arc length.
It turns out the approximation used is simple angular velocity addition
if angular velocity about ecliptic is w0 and angular velocity of precession is w1,
then their vector sum is the real angular velocity
[tex]\omega[/tex]= [tex]\omega[/tex]0 + [tex]\omega[/tex]1
now in one period T, [tex]\omega[/tex]0 contributes 2[tex]\Pi[/tex] because it is the motion in ecliptic and [tex]\omega[/tex]1's contribution is precession per orbit by definition which adds up to angle contributed by real motion.
First, it's important to note that the precession angle per orbit of perihelion precession of Mercury is not a fixed value, but rather varies depending on the specific model used to calculate it. This is because there are multiple factors that contribute to the precession of Mercury's orbit, such as the gravitational influence of other planets and the shape of the Sun.
In terms of your specific derivation, it's difficult to determine where the discrepancy may lie without seeing your calculations. However, it's possible that your equation may be an approximation or simplification of the more complex equations used to calculate Mercury's precession angle.
As for the intuition behind the approximation, it's likely that it is based on the assumption that the precession angle is small in comparison to the total angle traveled by Mercury in one orbit. This would make sense, as the precession angle is a relatively small deviation from the overall circular orbit of Mercury around the Sun.
In terms of your question about whether the total angle should be less than 2\pi + \Delta\Phi, it's important to remember that the precession angle is not a separate angle that is added on top of the circular orbit, but rather a deviation from it. So while the total angle traveled by Mercury may indeed be greater than 2\pi, the precession angle itself is still a small fraction of that total angle.
Related to Precession angle per orbit of perhelion precession mercury
1. What is precession angle per orbit?
The precession angle per orbit is the amount by which the orientation of a planet's orbit changes over time. It is caused by the gravitational pull of other celestial bodies, such as the sun and other planets.
2. What is perihelion precession?
Perihelion precession is the gradual change in the point at which a planet is closest to the sun in its orbit. This is caused by the influence of other celestial bodies and the deviation of the planet's orbit from a perfect circle.
3. How does perihelion precession affect Mercury's orbit?
The perihelion precession of Mercury's orbit is the highest among all the planets in our solar system. This means that its closest point to the sun gradually shifts over time, resulting in a change in the shape of its orbit.
4. What causes the perihelion precession of Mercury's orbit?
The perihelion precession of Mercury's orbit is mainly caused by the gravitational pull of other planets, particularly Jupiter. This causes a slight tug on Mercury's orbit, resulting in its gradual change over time.
5. What is the significance of studying the perihelion precession of Mercury's orbit?
Studying the perihelion precession of Mercury's orbit can provide valuable insights into the gravitational interactions between planets and other celestial bodies. It also allows us to better understand the dynamics of our solar system and make more accurate predictions about the movement of celestial bodies in the future.
10K
  • Astronomy and Astrophysics
  • Other Physics Topics
