Multi-Variable Second Order Taylor Series Expansion: Ignoring Terms
In summary, including some second order terms in a Taylor series expansion will always result in a more accurate approximation than just using first order terms, as long as the included second order terms are not 0. This can be seen by comparing the error terms for linear and second order Taylor series. However, the improvement in accuracy may vary depending on the specific function and the chosen variables for the second order terms.
cvanloon
So I'm computing a second order Taylor series expansion on a function that has multiple variables. So far I have this
I(x,y,t)=dI/dx(change in x)+dI/dy(change in y)+dI/dt(change in t)+2nd order terms
Would it still be a better approximation than just he first order if I included some second order terms and not others or no? To be more clear I would use something like this :
I(x,y,t)=First Order Terms+Ixx(dx^2)+Iyy(dy^2)
If this is better than just the first order terms, do you have an explanation as to why it is theoretically? Thanks,
Chris
No. Including some second order terms is never less accurate than the linear approximation and, as long as those included second order terms are not 0, will be more accurate. That can be seen by looking at the "error" terms for linear and second order Taylor's series.
Since this question says nothing about differential equations, why was it posted in this section? Did it arise in an attempted series solution to a differential equation?
Sure, it might be better, (but you probably also want an Ixy(dx dy) in there).
I don't think one can state as a general rule that this partial second-order expansion will be an improvement over the first-order. It is possible, at least in theory, that the second-order terms all nearly cancel, so that the first-order expression is accurate but any partial second-order expansion is worse. (Of course, these statements will only be true if, in approximating I, the differentials are replaced with specific finite numbers, such that the cancellation happens.) However, as a practical matter, one may know that there is much more action in the spatial dimensions than the temporal on scales of interest. Or maybe you have just chosen dt to be much smaller relative to Itt specifically to allow the neglect of the dt^2 terms.
I wasn't sure of a place to put it. Taylor series involve taking derivatives? ;) thanks for your answer though. Still looking for a solid mathematical reason why though. Thanks,
Chris
Thank you for your reply. Let's just say that you have no knowledge of what the function does and that you have second derivative information for I in x and y, but not xy t xt and yt. Would you rather use just the first order approximation or does "on average" or with greater probability, the few second order terms that you add improve your answer?
Thanks,
Chris
I think, in that case, that I'd agree with HallsofIvy: "on average", additional terms will improve the approximation.
Your question is vague, to say the least. It depends upon what you intend doing with your Taylor series expansion. Curve sketching, asymptotic expansion,...(?)
FAQ: Multi-Variable Second Order Taylor Series Expansion: Ignoring Terms
What is a Multi-Variable Second Order Taylor Series Expansion?
A Multi-Variable Second Order Taylor Series Expansion is a mathematical method used to approximate a multi-variable function by using a series of polynomials. It involves finding the derivatives of the function at a certain point and using those values to construct the approximation.
How is the Second Order Expansion different from the First Order Expansion?
The Second Order Expansion takes into account the second derivatives of the function, while the First Order Expansion only considers the first derivatives. This makes the Second Order Expansion a more accurate approximation of the function.
What does "Ignoring Terms" mean in the context of a Second Order Taylor Series Expansion?
Ignoring Terms refers to omitting certain terms in the expansion that have a small impact on the overall accuracy of the approximation. This simplifies the expansion and makes it easier to calculate.
What are some applications of Multi-Variable Second Order Taylor Series Expansion?
Multi-Variable Second Order Taylor Series Expansion is commonly used in physics, engineering, and economics to approximate complex functions. It can also be used in optimization problems to find the minimum or maximum values of a function.
What are the limitations of Multi-Variable Second Order Taylor Series Expansion?
One limitation is that it can only be used to approximate smooth and well-behaved functions. It is also limited to a specific point, so it may not accurately represent the function outside of that point. Additionally, the accuracy of the approximation decreases as the distance from the point increases.
