Pendulum (Conservative Forces and Potential Energy
In summary, the conversation discusses a physics problem involving a pendulum with a mass hanging from a rope. The problem includes questions about the tension in the string, the maximum mass that can be used with a given tension, the effect of a peg placed on the pendulum, and the magnitude of tension at different points in the pendulum's path. The conversation also mentions using the equations F=MA and PE=MGH to solve the problem. Ultimately, the conversation ends with the student understanding how to solve the problem with the help of hints from another person.
hawaldko
A mass m = 6.3 kg hangs on the end of a massless rope L = 2.13 m long. The pendulum is held horizontal and released from rest.
I already found the speed at the bottom of the pendulum's path and that is 6.46.
I'm stuck on:
a. What is the magnitude of the tension in the string at the bottom of the path? [br]
b. If the maximum tension the string can take without breaking is Tmax = 534 N, what is the maximum mass that can be used? (Assuming that the mass is still released from the horizontal and swings down to its lowest point.) [br]
c.Now a peg is placed 4/5 of the way down the pendulum’s path so that when the mass falls to its vertical position it hits and wraps around the peg. As it wraps around the peg and attains its maximum height it ends a distance of 3/5 L below its starting point (or 2/5 L from its lowest point).
How fast is the mass moving at the top of its new path (directly above the peg)? [br]
d. Using the original mass of m = 6.3 kg, what is the magnitude of the tension in the string at the top of the new path (directly above the peg)
My book doesn't give any specific formulas for tension.
So I have F=MA and PE=MGH
a. I tried just MG originally and the solution checker told me that T had to be greater than MG, so I used the velocity and did .5mv^2+mg and it said it was wrong. I read some stuff online and it suggested 2MG and that was also marked wrong. I honestly have no clue whatelse to use. I've tried all of the answers both positive and negative.
b. I didn't really know what to do for this one, I just divided the tension by gravity and the online checker said "It looks like you assumed the tension only has to hold the weight. However, the tension must be greater to accelerate the mass upward in circular motion." I really don't know where to go from there, because I think I need to use the same process as in A.
c. I have no idea where to even start on this one. I know I'm supposed to show what work I tried, but I've just been staring at the problem. I think it will make the velocity less, but I don't know what to do.
d. Since I didn't know how to do the problem before this, I think I need values from that, and I don't really understand tension.
[p]
I'm so sorry that I have so many questions, but I'm just beyond lost on this problem. I tried to go to tutoring at my school, but no one showed up to help me since it's so early in the year. I would appreciate any help what so ever.
a. Well, the pendulum is moving in a circle. Ignoring the string for a moment, you want the net force to be mv^2/r, which is the formula for centripetal force. You know v, r, and m. Gravity provides a force mg downward. What should tension be so the net force is the required centripetal force upwards?
b. When you did part (a), you got an expression for tension in terms of mass, velocity, and radius. Keep v and r plugged in but don't substitute for mass, since that's what you're looking for. Set equal to the tension and solve.
c. This is the beauty of using energy to solve problems! You can have the weirdest, more complex forces acting and still be able to find the answer. In this case, it's pretty difficult to find what the tension actually is, so don't bother. No nonconservative forces acted, so energy (KE + PE) is conserved.
d. This is part (a) with a little twist. Use your result from part (c).
Good luck! If you need more help I'll post a full answer later.
I'm sorry...I kind of need some more help.
a. mv^r=121.149 and mg=61.74. I tried adding them together, but the solver said I was wrong. I'm not sure what else to do with the numbers.
I got it!
Thank you so much. I probably read your hints a hundred times, but they finally clicked!
No problem- that's what this forum is for!
1. What is a pendulum?
A pendulum is a weight suspended from a fixed point that is able to swing freely back and forth due to the force of gravity.
2. What are conservative forces?
Conservative forces are forces that are path independent, meaning the work done by the force on an object is only dependent on the initial and final positions of the object and not the path taken between them.
3. How does potential energy relate to a pendulum?
A pendulum has both kinetic and potential energy. The potential energy of a pendulum is due to its position relative to the Earth's gravitational field. As the pendulum swings, this potential energy is converted into kinetic energy and back again.
4. What is the equation for the period of a pendulum?
The equation for the period of a pendulum is T = 2π√(L/g), where T is the period in seconds, L is the length of the pendulum in meters, and g is the acceleration due to gravity in meters per second squared.
5. How does the length of a pendulum affect its period?
The period of a pendulum is directly proportional to the square root of its length. This means that as the length of a pendulum increases, the period also increases, resulting in a slower swing.
22K
