Schrodinger Equation and seperation of variables
In summary, Griffiths claims that a superposition of separable solutions of a differential equation can always give us the general solution. However, this result is only true if the coefficients of the PDE are analytic functions and the potential is independent of time.
McLaren Rulez
292
Hi,
In Griffiths QM, it is claimed that to solve the Schrodinger Equation, we take the solution wavefunction [itex]\Psi(x,t)[/itex] to be of a seperable form [itex]\psi(x)\phi(t)[/itex].
He then says that a superposition of these seperable forms can always give us the general solution. Can someone help me prove that statement? How do I know that every solution [itex]\Psi(x,t)[/itex] is a linear combination of solutions of the form [itex]\psi(x)\phi(t)[/itex]
Thank you!
This is not mainly caused by the fact that these are solutions to the differential equation. It is just that, in general, you can write any suitably well-behaved function F(x,y) as a linear combination:
[tex]F(x,y) = \sum_{i,j} c_{ij} f_i(x) g_j(y)[/tex]
where c_ij are the coefficients and f_i/g_i are functions spanning the complete x/y function space, respectively. The solution functions of the separated problems give you such sets normally.
The separation ansatz just gives you a set of such functions which is likely to be sensible in some regard (i.e., to not require overly many such product functions to approximate a real solution to a desired degree). This works best if the degrees of freedom you are separating into are only loosely coupled---or actually independent. And of course, any linear combination of solutions of a linear differential equation will also be a solution to the differential equation.
The separable form is a convenience only, textbook example. One can offer nonseparable solutions for various potentials. As for the superposition, i don't think it's true.
"Superposition" of solutions to get a general solution is true for any linear differential equation.
So is there a proof for this result? That the general solution of any linear DE is a superposition of the separable solutions. Thank you!
You're postulating too strong of a result.
To start, we must have results on existence and uniqueness of solutions to the initial or boundary value problem for a given differential equation. If the coefficients of the PDE are analytic functions (admit a locally-convergent power series expansion), then a major result is the Cauchy–Kowalevski theorem. This result establishes the existence and uniqueness of an analytic solution to the initial value problem.
I'm no expert on the subject, but the online notes at http://www.math.ucdavis.edu/~hunter/pdes/pdes.html seem to be a nice treatment. The heat and Schrodinger equation (at least in one space dimension) are discussed in Ch. 5.
Now, certain PDEs admit separable solutions. If we can establish a separable solution to an initial value problem that satisfies the restrictions of the Cauchy–Kowalevski theorem, then we can conclude that it is the unique solution.
Next, we can ask what PDEs will admit separable solutions. The time dependent Schrodinger equation
$$ i \partial_t \Psi(\mathbf{x},t)= \hat{H} \Psi(\mathbf{x},t)$$
$$ \hat{H} = - \Delta + V(\mathbf{x},t)$$
separates in space and time when the potential is independent of time, ##V(\mathbf{x},t)= V(\mathbf{x})##. Similarly, the time-independent Schrodinger equation
$$ \hat{H} \psi(\mathbf{x})= E \psi(\mathbf{x})$$
will admit separable solutions whenever there is some symmetry of the potential that would cause
$$\frac{d V(\mathbf{x})}{du} =0,~~~ u = f(\mathbf{x}).$$
This is a complicated way of saying that there is a change of variables such that the potential function is independent of at least some of the variables. In principle, there are even time-dependent potentials that are separable after a change of variables that mix space and time coordinates.
The key term is Sturm-Liouville. A Sturm-Liouville differential equation can be cast in terms of a Hermitian differential operator, and its solutions written in terms of functions that are eigenvectors of this operator. One then can bring to bear the full machinery of linear operators in a Hilbert space to write the general solution as a linear combination of the eigensolutions.
Excuse me if I am wrong but if we separate variables like ψ(x)[itex]\phi[/itex](t), then we would be eliminating any possibility of motion for the particle since [itex]\phi[/itex](to), for any to, would affect equal to all the points in the space and the integral of |ψ(x)|2 for all the space must be equal to zero, so there would not be flux of probability.
1. What is the Schrodinger Equation?
The Schrodinger Equation is a fundamental equation in quantum mechanics that describes how the wave function of a quantum system evolves over time.
2. What is the significance of the Schrodinger Equation?
The Schrodinger Equation is significant because it allows us to calculate the probability of finding a particle in a particular state, and it provides a way to understand and predict the behavior of quantum systems.
3. What is the process of separation of variables in the Schrodinger Equation?
The process of separation of variables involves breaking down the Schrodinger Equation into simpler equations by separating the variables (time and space) and solving them separately.
4. Why is separation of variables important in solving the Schrodinger Equation?
Separation of variables is important because it simplifies the Schrodinger Equation and makes it easier to solve. It also allows us to break down the problem into smaller, more manageable parts.
5. How is the Schrodinger Equation used in real-life applications?
The Schrodinger Equation is used in many real-life applications, including the study of atomic and molecular structures, quantum computing, and the development of new materials. It also plays a crucial role in understanding and predicting the behavior of subatomic particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
