Mass can turn into Energy, or is it Matter which can turn into energy?
In summary, Matter and energy are two ways of measuring the same thing. Every system has both mass and energy, as they are equivalent. Therefore, matter has both mass and energy. Mass cannot be converted into energy, as they are fundamentally the same.
jacket
32
What's the difference between Mass and Matter? Which of them is equivalent to energy?
Can mass exist without matter?
What does the universe mainly contain? :
Mass and Energy
or
Matter and Energy
mass is just a property of matter.They are kinda one and the same.There is no abstract mass somewhere out there that has no matter attached to it.
Not all matter has mass , some of it is massless like photons , but that another story.
Everything that has mass also has energy, potential, kinetic or otherwise.
The explored universe mainly contains just matter , but there is a huge portion which we don't know yet , we have a fancy word for it " dark matter" not because it's dark but rather because we have a rather " dark picture" of it as of yet.
Anyways whatever is out there must be something physical of that you can be sure.
Matter is composed of fundamental particles. Mass is a measurable quantity associated with both matter and energy.
Absolutely. A box with light inside has more mass than a box without light. Or, if you want to get rid of the box idea, we can say that a volume of space with lots of light in it has more mass within it than a volume of space with no light inside, everything else being identical.
Mass and Energy
or
Matter and Energy
Ignoring dark energy, as that gets confusing when talking about what the universe is composed of, the majority of the universe is mass in the form of dark matter.
Ok. So when we say 'mass turns into energy' then actually we are saying 'a measurable quantity associated with both matter and energy turns into energy'. Sounds confusing to me.
Also if only 'a measurable quantity associated with matter turns into energy' then where is the left out (matter without mass) ? And what is that?
Yes, it's a bit confusing.
To quote wiki:
In physics, mass (from Greek μᾶζα "barley cake, lump [of dough]") is a property of a physical system or body, giving rise to the phenomena of the body's resistance to being accelerated by a force and the strength of its mutual gravitational attraction with other bodies.
To make it even more confusing, certain units of measurement, like the electron volt, can refer to BOTH mass and energy.
Mass is typically used to refer to the invariant quantity of energy a system has in its own rest frame. For example, a rocket traveling at 99% c will have zero kinetic energy in its own frame of reference, whereas in the frame we are measuring its velocity against it will have a great amount of kinetic energy. However the mass of the rocket will remain the same no matter what frame we measure from, as will the energy associated with this mass. Having a term like "mass" makes it much easier to do physics.
There is no matter without mass. All fundamental particles have mass, as do the composite objects they build into.
Edit: Photons are not usually considered to be matter.
Mass doesn't "turn into" energy. Mass has energy, and energy has mass.
If so, then Matter has mass and mass has energy and again energy has mass...
Who 'has' the property and who 'is' the property?
Perhaps another way of looking at it will help.
Instead of saying energy has mass, we could say that X amount of mass is equal to Y amount of energy. For example, a kg of mass is equal to approximately 9x1016 joules and vice versa. It doesn't matter which unit you use, the overall effects are the same.
I don't think that question has any scientific meaning.
How could you experimentally test that question?
Ok let me restate my original question:
If we can say X amount of mass is equal to Y amount of energy,
Can we say J amount of matter is equal to K amount of energy?
Yes we can.
Mass converts to energy per E=mc^2.
All matter has mass.
But matter is a non-technical term. Matter = stuff. Most people would say that matter is made up of atoms, atoms are made up of fundamental particles.
Provided that J is measured in units of mass, then yes, where K = J c².
Likes 1 person
Conclusions: (are they all correct?)
1. Mass and energy are two ways of measuring the same thing.
1. Every system has mass or energy or both (as mass and energy are equivalent)
2. Thus, Matter has mass or energy or both.
3. Mass of a matter can not be 'converted' into energy in the sense that they are actually same thing.
The first 1. and 3. are fine, but I would restate the second 1. and 2. as follows:
1. Every system that has mass has energy (as mass and energy are equivalent)
2. Thus, Matter has both mass and energy.
By the way, I thought that I should clarify, the mass I am discussing here is "relativistic mass". There is another definition of mass called "invariant mass" which has a slightly more complicated relationship to energy. Specifically: ##m^2 c^2 = E^2/c^2 - p^2##
Likes 1 person
Also note that most of the time (>90%) when physicists use the word mass they mean rest mass not relativistic mass. Rest mass is not equivalent to energy since their relationship also includes the momentum p. If you ask my opinion, I would abolish the concept of relativistic mass all together since it is more trouble than it is worth.
Mass is a measurement of matter, which is any physical substance. Matter and energy are not necessarily the same thing, although all matter contains some degree of potential energy. Einstein's theory E=MC^2 states that the amount of energy in matter (E) equals its mass (M) times the speed of light (C) squared.
This is the best answer I think. You don't really need the word "matter" in physics at all, it adds nothing new to any theory.
I hope now I am correct:
Relativistic mass is a measure of systems Energy.
Energy is a measure of system's Relativistic mass.
Matter or it's mass, doesn't 'turn into' energy.
Relativistic mass and Energy are two ways to represent a same thing.
Er.. no, I think you've made it worse.
We usually do not deal with "relativistic mass". In fact, in many circles, this term is seldom used.
Mass can be converted into energy, and energy can be converted into mass. These are "invariant mass", and that is the only mass that matters (no pun intended).
I am not sure why you have a problem with each one being converted into the other, or why you need to make a distinction between "relativistic" mass etc.
Zz.
And perhaps Matter has nothing technical to do in the "mass-energy equivalence".
We have no idea what you mean by "matter", or what "nothing technical" actually means.
Unless you know of something, you shouldn't be making statements such as this or you'll run afoul of our rules on speculative post.
Zz.
I am not sure why you have a problem with each one being converted into the other,...
Zz.
Perhaps I should post a link . http://plato.stanford.edu/entries/equivME/
Everything 'written' next (except the end note) is quoted from this article:
Zz.
In relativistic physics, as in classical physics, mass and energy are both regarded as properties of physical systems or properties of the constituents of physical systems. If one wishes to talk about the physical stuff that is the bearer of such properties, then one typically talks about either “matter” or “fields.”
Are mass and energy the same property of physical systems and is that what is meant by asserting that they are “equivalent”?
The first interpretation (Torretti, Eddington) we will consider answers “Yes” to the first interpretative question posed above: mass and energy are the same property of physical systems. Consequently, there is no sense in which one of the properties is ever physically converted into the other.
Lange (2001, 2002) has recently suggested a unique interpretation of mass-energy equivalence. Lange begins his interpretation by arguing that rest-mass is the only real property of physical systems. This claim by itself suggests that there can be no such thing as a physical process by which mass is converted into energy...
Note:
Zz.
I apologize if it seems like that.
It is difficult to carry any kind of rational conversation when one is talking to a series of quote taken from somewhere else.
Please note that you asked the question. When I asked for clarification on what you meant, you gave me nothing but a series of quote from another source. I don't even know if you actually understood what you quoted. Do you even know the physics involved in the source that you are citing?
A lot of these are "semantics", not physics! Anyone who thinks that the e-p pair is identical to photon that created it has a lot of explanation to do!
If you read something, and you didn't understand it, then cite it and ask! Don't respond to something by simply quoting off some webpage or source. A parrot can do that as well!
Zz.
Well, okey ZapperZ, you are the Mentor here. I expect help from you.
Anyone reading this post with a rational mind will see, whenever I try to say something from my own or try to clarify what I am trying to say, you reply like
I am not "Making statements", I am trying to know if those statements are right or do they make sense at all. I got some ideas by studying some texts and felt confused when I tried to understand those concepts. And so I asked here, for a discussion to clarify my confusions. And I did't 'invent' anything.
Even if I show you one example of from where I got those ideas, you say,
I am 'quoting' because if I don't quote, you are saying I am making 'foul statements'.
Now I wonder why you don't Correct my 'foul statements' and explain things clearly? Or explain the contradiction of concepts? (I think *now* many viewers would be happy to get the explanation.)
It doesn't matter really. If I understood, then I wouldn't have asked here. And if you understood (which of course you did) you can explain.
"If you can't explain it simply, you don't understand it well enough." - Albert Einstein
Applies to everyone!
Note what I also said that you neglected to quote:
I asked you something, and you REPLIED by simply rattling off a bunch of quotes. You did not indicate whether you understood this and using the quotes as a reply to me, or if you didn't understand what you quoted (which is a rather silly way of having a discussion).
If you have read this, and you didn't know what they mean, and you want to learn what it is, then you should have (i) cited the source (ii) quote the exact passage that you didn't understand (iii) then ask what it is that you did not understand!
Look at the way you did this here. You quote my questions or statements, and then it looked as if you were replying to them simply by using a bunch of stuff you copied off that site! Nowhere in that post did you indicate anything to the effect that you were "... trying to know if those statements are right or do they make sense at all... " Go look at it again if you think I'm making this up.
BTW, subjecting physics to definitions and principles made up in Philosophy is as cruel as subjecting scientists to a pseudoscience act such as a lie detector.
https://www.physicsforums.com/blog.php?b=3722 Zz.
Sometimes, even Albert Einstein was provably wrong.
I go with ZapperZ here.
:smile:
No, no ZapperZ. I wasn't 'replying' to your answer, I was just 'quoting' to mark the contradictions (or ask if there are any), which were very confusing to me.
I tried to say that by
But I agree, perhaps that wasn't the right way to do it. It led to an unwanted misunderstanding, and unintended conversations.
I am just in basic physics now (my study). And at this beginning stage I have (at least I hope I have) very introductory ideas about Mass, Energy, Relativistic mass etc but whenever I go to understand what those definitions actually 'mean' I often get confused.
And of course when I quote Einstein, I know that quote was not a 'law of physics'.
Anyway, here I try to restate my question https://www.physicsforums.com/showthread.php?p=4557264#post4557264
(I hope this time I am doing it right way)
Now, I think this thread has come to its end.
Hi ZapperZ, I agree with the point that relativistic mass is seldom used, and in retrospect I wish that I had responded in terms of invariant mass, however, since jacket specified that he was talking about relativistic mass I don't see anything actually wrong with what he said.
I think that is all correct. Relativistic mass is proportional to energy, with a constant of proportionality of c². So I think of them as rather synonomous.
Likes 1 person
What is the relationship between mass and energy?
The relationship between mass and energy is described by Einstein's famous equation, E=mc². This equation shows that mass can be converted into energy, and vice versa.
How is mass converted into energy?
According to Einstein's equation, mass can be converted into energy through a process called nuclear fusion. In this process, the nuclei of atoms are combined, releasing a tremendous amount of energy.
Can any type of matter be converted into energy?
Yes, any type of matter can potentially be converted into energy. However, the amount of energy that can be produced depends on the mass of the matter and the efficiency of the conversion process.
What are some real-life examples of mass being converted into energy?
Nuclear power plants use the process of nuclear fission to convert tiny amounts of matter into large amounts of energy. The sun also converts mass into energy through nuclear fusion, providing the Earth with heat and light.
What are the implications of understanding mass-energy equivalence?
The understanding of mass-energy equivalence has led to advancements in nuclear energy, as well as the development of nuclear weapons. It also plays a crucial role in the study of the universe and the fundamental laws of physics.
  • Other Physics Topics
  • Cosmology
