- #176
Dale
Mentor
- 35,642
- 13,997
I agree. By the way, I really like how you not only specified what you wanted to measure, but also the experiment to measure it.Bjarne said:Let's say it really was possible to tie a tape measure to the North Pole of the Sun and to the North Pole of the Earth in the other end.
A and B is in this example only observers to the Earth orbiting the Sun.
Both can see the radius / circumstance of the orbit of the Earth and both agree that the orbit of the Earth (as just defined) really is the same for both observers, - simple because both can observe this is how the tape measure proves it to be.
That would be true if spacetime were flat. I.e. in flat spacetime A not moving relative to B implies that A and B are at rest in the same frame. However, the spacetime is not flat, but is curved, and in curved spacetimes reference frames are local. For example, although the distance wrt each other is not changing (an indicator of the same frame in flat spacetime), signals from A are redshifted when received by B (an indicator of different frames in flat spacetime). So A and B are not considered to be using the same reference frame despite the fact that they are not moving relative to each other.Bjarne said:They are not moving relative to each other and also not relative to the Earth.
A and B and the Earth is all exactly following the same orbit, and hence in the same frame.
Besides, haven't you been assuming that A and B are different reference frames and therefore claiming that the laws of physics are different in different reference frames? It seems strange for you to change your position on this topic after this long when it hasn't been a point of disagreement until now.
