Question about light waves canceling each other
In summary: You need beam splitters to do this. Where recombination takes place, two rays enter and two rays leave. The intensity ratio of the beams leaving depends on the phase of the beams entering.In summary, the beams will not cancel each other, but will still result in an interference pattern.
bouscher
Hello fellow physicists :)
I have the following question:
take a beam of light traveling in some direction x, let's use lasers due to their coherency and monochromatic properties.
Now let's take another nearly identical beam traveling in the same direction x, only that it's 180° in phase with the other beam.
Assuming that the beams overlap each other, what would actually happen? Will the cancel each other? And if so, won't it violate the Energy Conservation principle?
Notice that the beams emanate from the "same" source and travel in the SAME direction, not opposite to each other (then constructive and destructive interference should occur).
This question is also pointed towards sound waves (Not this forum I guess), meaning: What would happen when two identical yet 180° phase different pressure waves emanate from the same source and travel in the same direction.
Thanks in advance! :)
Science news on Phys.org
Easy. This is equivalent to the source not emanating radiation at all.
That's exactly what I thought, but how do you resolve the issue with light waves?
Which issue?
The issue is that theoreticly, one could create such a situation with light waves
I don't doubt this. I just want to say that if you couple two lasers in such a way that the light beams are 180 degrees out of phase they won't laser at all.
On the other hand I can describe any fieldless situation as a superposition of two fields being 180 degrees out of phase.
But why do you say that "theoreticly [sic], one could create such a situation"? DrDru has already told you that such a system does not radiate.
Lets take a laser beam, split it into 2 beams, pass one through vacuum and the other one through a gas filled tube, and then recombine them and you get a combination of 2 identical laser beams with different phases, and that I've managed to do in a lab. I indeed got an interference pattern due to the phase change, but my question is what kind of image might I get when both beams are perfectly aligned. I think that the experiment that I've done (It was in order to find the refraction index of different gasses) shows that if the beams are 180° phase different, you won't see any light hitting the screen (you'll get something due to the beams being unaligned).
I think the answer might be that light is both a wave and a particle, and that the energy keeps moving in the particle form rather than the wave form.
This question has popped up periodically. Check out this thread:
https://www.physicsforums.com/showthread.php?t=306962
I've given, in that thread, a very good paper that explains this conservation issue.
Zz.
You can get total destructive interference and loss of EM energy in the presence of matter, i.e. the waves do work on the matter e.g. the recombiner. In the absence of matter if you have destructive interference in one place you will always get constructive interference in another place and the total energy of the wave is conserved. Here is my favorite proof, it applies for any situation governed by Maxwell's equations:
http://farside.ph.utexas.edu/teaching/em/lectures/node89.html
The situation you are describing is completely classical. No need to go into quantum stuff.
Thanks people :) I'll be sure to look into those links...
Related to Question about light waves canceling each other
1. How do light waves cancel each other?
Light waves cancel each other when they have equal amplitude but opposite phases. This means that the peaks and troughs of the waves are aligned in opposite directions, resulting in a net amplitude of zero.
2. What is the principle of superposition in relation to light waves cancelling each other?
The principle of superposition states that when two or more waves meet at a point, the resulting displacement is equal to the sum of the individual displacements of each wave. In the case of light waves cancelling each other, this results in a net displacement of zero.
3. Can light waves of different colors cancel each other?
Yes, light waves of different colors can cancel each other if they have the same amplitude and opposite phases. This is known as destructive interference.
4. How does the distance between light sources affect the cancellation of waves?
The distance between light sources does not affect the cancellation of waves. As long as the waves have equal amplitude and opposite phases, they will cancel each other regardless of the distance between the sources.
5. Is the phenomenon of light waves cancelling each other observed in everyday life?
Yes, the phenomenon of light waves cancelling each other is observed in everyday life. For example, when you see a rainbow, the colors of the rainbow are created by light waves of different colors cancelling each other at different points in the droplets of water in the air.
