How Do Electrical Equations Help Calculate Charge and Electron Flow in Circuits?
  • Thread starter Thread starter runicle
    Electrical
The discussion focuses on understanding key electrical equations and variables used to calculate charge and electron flow in circuits. The variables include the charge of an electron (e), the total charge (Q), and the formula for current (I), which relates charge to time. A current of 0.82 A flowing for 10 minutes results in a charge of 492 Coulombs, but a discrepancy with the book's answer suggests a calculation error. For calculating the number of electrons, knowing that one Coulomb equals approximately 6.24 x 10^18 electrons is essential. The conversation emphasizes the importance of correctly applying these equations to solve electrical problems.
runicle
Can you please explain me in lamens terms what are these variables names and what they give:
1c=6.24 * 10^18
e=1.60 * 10^-19
Q=Ne
Fe=KQ1Q2/d^2
I=Q/T
1A = 1C/1s
And How would i do this question with the stuff i have written above this line?
A current of 0.82 A flows through an electric lamp for 10 min. In that time how much charge passes a given spot in the filament expressed in
(a)Coulombs
(b)Electrons
For (a) i think I need to use 1A = 1C/1s
So C=A*S
-C=0.82 A (600s)
-C=492
But in the back of my book its -492 explain what i did wrong
For (b) I think i don't know what to use I'm
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
