How an Induction Stove Works Explained
In summary: With induction heating, all of those different alloys can be heated to the same temperature and then quenched together, resulting in a single, consistent piece of steel that can be machined or formed to any shape or size without any problems.In summary, an induction stove uses induction heating to get the job done. The coil near the casserole pan creates a field that pushes and pulls the electrons around, making the pan hot.
TSN79
424
Can someone explain to me how an induction stove works? I know it has something to do with magnetism, but how the casserole can get hot while the surface of the stove itself does not blows my mind!
Anyone?
Anyone?
In short, there's a coil if wire near the casserole pan. A current of electrons whizzes round in the coil and creates a field around it. When that field hits the pan it 'pushes and pulls' the electrons around inside the material it's made of. As the electrons in the pan get pushed and pulled around they heat up the pan, just like a piece of wire gets hot if you try to put too much current through it. That's why the pan has to be metal, or something else that's conductive, the coil has to be able to move the electrons around in things to make it hot. Because you don't want to have to plug in your pans to heat them up, the oven -couples- onto them with a magnetic field to achieve the same effect.
The coil doesn't care what is put in it so long as it can move electrons around. So ceramics won't heat up because they're excellent insulators, at room temperature anyway; a lot of the best superconductors are ceramics but need to be at cryogenic temperatures before they take on the weird properties of superconduction.
If you stove was powerful enough it could melt the metal containers you put on it. The food inside is acting like coolant, or radiator fluid, soaking up the heat from the metal.
Ovens just like your's, but much more powerful, are used industrially to melt metal. They're often used for metals that would be contaminated by normal flame heating or that need very specific cooking times and temperatures (annealing, meaning to soften, as well as tempering, to harden).
You can see some good video clips of induction heating being used industrially here;
http://www.ameritherm.com/videoindex.html (Notice how quickly the parts heat up)
The Precison Induction Heating video is the best to watch first. The rest are examples of the company's work.
We also use induction heaters to heat bearing assemblys before installation id the shaft fit is tight enough.
Induction heating is also extremely widely used in heat treating metals. A given alloy has an optimum temperature for hardening (and also for tempering). Induction heating allows for precise control of the temperature to which the metal is heated before quenching. This has allowed for automated, consistant, mass heat treatment of parts.
This has been particularly useful in the automotive industry. I once saw a figure for the number of different alloys of steel that go into the average car and was astonished. It was over a hundred, I think, each requiring heat treatment at a specific temperature.
Related to How an Induction Stove Works Explained
1. How does an induction stove heat up food?
Induction stoves use electromagnetic energy to create heat. When an electric current is passed through a coil of metal underneath the stove's surface, it creates a magnetic field. This magnetic field then interacts with the metal cookware, causing it to heat up and cook the food inside.
2. Are induction stoves more efficient than traditional stoves?
Yes, induction stoves are typically more efficient than traditional stoves. This is because traditional stoves use gas or electric heating elements that lose heat to the surrounding air, while induction stoves heat the cookware directly.
3. Do I need special cookware for an induction stove?
Yes, in order for the magnetic field to work, the cookware used on an induction stove must be made from a magnetic material, such as cast iron or stainless steel. Non-magnetic cookware, such as aluminum or copper, will not work on an induction stove.
4. Can an induction stove be dangerous?
Induction stoves are generally safe to use, but there are some precautions that should be taken. Since the stove's surface does not heat up, there is a lower risk of burns from touching it. However, the cookware and the food inside can still become very hot, so caution should be taken when handling them. Also, the magnetic field can interfere with certain medical devices, so individuals with pacemakers or other implants should consult their doctor before using an induction stove.
5. How does an induction stove compare to a gas or electric stove in terms of cooking speed?
Induction stoves are known for their fast cooking times. They are typically faster than gas stoves and about equal to or slightly faster than electric stoves. This is because the heat is generated directly in the cookware, rather than having to heat up a heating element first.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
