Index of refraction find a wavelength
The discussion revolves around finding the wavelength of light in a medium given its index of refraction. The subject area pertains to optics and wave behavior in different media.
  • Participants explore the relationship between the speed of light in a medium and its wavelength, questioning the use of the wave equation. There is discussion about how the refractive index relates to the speed of light in different media and the implications for wavelength.
Some participants have provided insights into the relationship between the speed of light in a medium and its refractive index, while others have raised questions about the dependency of the refractive index on the color of light and its effect on wavelength. Multiple interpretations of the problem are being explored.
Participants note that the speed of light varies in different media and that the refractive index is color-dependent, which may affect the wavelength calculations. There is an emphasis on understanding the fundamental relationships rather than arriving at a specific solution.
Anieves
Given any index of refraction, how would I find a wavelength in that medium? Should I use frequency= c/wavelength? For example, if a piece of glass (medium) has a index of refraction 1.12, what's the wavelength?
Yes, you'd use the basic wave equation: [itex]v = f \lambda[/itex], where v is the speed of light in the medium of interest. (If c is the speed of light in air/vacuum, what is the speed of light in a medium with index of refraction n?)
You may need a relationship as a function of speed-of-light-in-vacuum and speed-of-light-in-medium.
According to the definition of refractive index of a medium, say glass, [itex]n_g[/itex]
we have that
[tex]n_g\eq \frac{c}{v}[/tex]
where c is the speed of light in vacuum and v is the speed of light in the glass, which is less than the speed of light in vacuum, that is light travels slower in an optical dense medium. The various colors of light are not slowed down by the same amount thought. Therefore we find that blue light is lowed down more than red light in glass. Therefore the refractive index is color dependent (it is different for the various colors of light, even for the same medium).
This phenomena is called dispersion. For wave phenomena we know that
[tex]v=\lambda' f[/tex]
What happens is that the frequency of the wave stays the same as it enters the glass, but its wavelength,[itex]\lambda'[/itex], is altered in the optical dense medium.
