Easy Guide: Converting km/h to m/s in Physics Class
  • Thread starter Thread starter kfink85
To convert kilometers per hour (km/h) to meters per second (m/s), divide the speed in km/h by 3.6. For example, to convert 82.4 km/h to m/s, you would calculate 82.4 / 3.6, resulting in approximately 22.9 m/s. This conversion is based on the fact that there are 1000 meters in a kilometer and 3600 seconds in an hour. Understanding this relationship simplifies the conversion process significantly. Mastering this conversion is essential for physics calculations involving speed.
kfink85
I am in my first physics class and the professor just kinda skimmed over this but I am lost on how to convert km/h to m/s.
What's the explanation on how to convert 82.4 km/h to m/s?
Thanks in advance for any help.
There are 1000 m in one kilometer.
There are 60 seconds in an hour.
If you want to change from km/h to m/s, you need to divide by 1000 and multiply by 60. Think of it as multiplying by 1: 1 km/h * (1000m/km) * (1h/60s)= (1000/60) m/s
Thanks very much.
What I usually do is
\frac{1\ km}{1\ h}=\frac{1000\ m}{3600\ s}
which gives
1\ km/h=\frac{1}{3.6}\ m/s
or
1\ m/s=3.6\ km/h
