Scatter vs Diffusion: What’s the Difference?
  • Thread starter Thread starter dervast
    Diffusion
Scatter refers to the deflection of light when it interacts with a medium, typically involving fewer, more spaced-out changes, while diffusion involves numerous closely spaced interactions that collectively alter the light's path. In scattering, a single event, such as a photon hitting an electron, results in a change of direction, whereas diffusion occurs when light passes through a medium like fog, undergoing many interactions that blend together. The distinction lies in the number and proximity of interactions: scattering is less complex, while diffusion represents a cumulative effect. Understanding these concepts is crucial for grasping how electromagnetic waves behave in different environments. The conversation clarifies that while scattering can lead to diffusion, they are fundamentally different processes.
dervast
Hi. I want to know what's the difference between scatter and diffusion... I am trying to understand what happens to the electromagnetic wave when we are talking about scattering and about light diffusion.. I think that the result of scattering it to make the light to diffuse.. Is that right?
Science news on Phys.org
Scattering usually is used when the number of changes by the medium is small and somewhat separated. Diffusion is used when there are a large number of changes and the separations are small.
Thx a lot for your answer but can u plx expalin me a little more what u have said above
For example - a photon (gamma ray) hits an electron and changes direction. This is a single scatter. Alternatively - light going through a fog undergoes many interactions (individual scatters don't mean much) This is diffusion. To some extent, quantitative difference becomes qualitative.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
