Why Does FCC's Reciprocal Lattice Cube Side Equal 4π/a?
  • Thread starter Thread starter TheDestroyer
    Lattice Reciprocal
The length of the cube side in the reciprocal lattice of a face-centered cubic (FCC) structure is equal to 4π/a, where 'a' is the lattice constant. This relationship arises because the reciprocal lattice of an FCC is a body-centered cubic (BCC) lattice, which has a lattice constant of 4π/a. The mathematical derivation involves using the primitive reciprocal lattice vectors and the symmetry of the FCC structure. By substituting the FCC basis vectors into the reciprocal lattice equations, it becomes clear that the coefficients align with those of the BCC structure. Understanding this connection clarifies the factor of 4 in the reciprocal lattice calculation.
TheDestroyer
If we are studying FCC in the direct lattice, Why does the length of the cube side in the reciprocal lattice equal to 4*Pi/a Where a is the lattice constant,
a*=|G|=2*Pi/a Sqrt(4) = 4*Pi/a
Where a* is the length of the cube site in reciprocal lattice
Note: this thing is repeated in 2 problems and i wouldn't be able to know the reason.
Prefessor is writing it like this but i can't understand (LOL, he also doesn't know to answer me when i asked him, he's just reading from papers, Silliy Professors)
Any one can explain? thanks
the factor 4 is usually left there to make it clear that fccs reciprocal lattice is the bcc lattice with a lattice constant of 4pi/a.
Can you explain it in mathemtical way? because this explanation is refused when it's said like that!
Thanks
allright. let's look at the primitive reciprocal lattice vector b1 of the fcc lattice. the a vectors are the direct space primitive lattice vectors.
b_1=2\pi \frac{a_2 \times a_3}{a_1 \cdot (a_2 \times a_3}
Just plug in the fcc vectors and do the cross products and you'll get
b_1=\frac{4\pi}{a} 1/2(y+z-x)
which is the a1 for bcc with a lattice constant of 4pi/a.
OK! Why did you put 1/2?
I know the reciprocal of fcc is 2Pi/a (-x+y+z)
Why did you multiply and device by 1/2?
HERE IS THE QUESTION :P
Thanks
The half is there just to show the connection between fcc and bcc in direct and reciprocal space.
The basis vectors of an FCC in a symmetric form are :
a_1=\frac{a}{2}(\hat{x} + \hat{y})
a_2=\frac{a}{2}(\hat{y} + \hat{z})
a_3=\frac{a}{2}(\hat{z} + \hat{x})
If you plug these into the equation provided by inha in post#4 for the reciprocal lattice vectors, you get :
b_1=\frac{2\pi}{a}(\hat{x} + \hat{y} - \hat{z})
b_2=\frac{2\pi}{a}(\hat{y} + \hat{z} - \hat{x})
b_3=\frac{2\pi}{a}(\hat{z} + \hat{x} - \hat{y})
(also, as posted by inha in post #4)
The trick, next, is to recall that the basis vectors for a BCC, in symmetric form are :a_1=\frac{a'}{2}(\hat{x} + \hat{y} - \hat{z})
a_2=\frac{a'}{2}(\hat{y} + \hat{z} - \hat{x})
a_3=\frac{a'}{2}(\hat{z} + \hat{x} - \hat{y})
where a' is the BCC lattice parameter (or cube edge).
Since these have the same form as the reciprocal vectors of the FCC, we understand that the reciprocal lattice of the FCC is in fact, a BCC.
Secondly, comparing coefficients, we find that :
\frac{2\pi}{a} = \frac{a'}{2}
\implies a' = \frac{4\pi}{a}
Thanks, I got it
TheDestroyer said:
Thanks, I got it
I think it is quite easy. By normally calculate we can get b=4*pi/a for fcc and bcc
