What’s the Impact of Momentum vs. Energy in Bullet Performance?
  • Context: Undergrad
  • Thread starter Thread starter phil
The discussion centers on the impact of momentum versus kinetic energy (KE) in bullet performance, specifically regarding how these factors influence the "kick" of a bullet and its damage potential. It is established that while momentum is often overlooked in gun discussions, it plays a crucial role in the perceived recoil or kick of a bullet. The relationship between kinetic energy and damage is also highlighted, with the consensus that higher KE generally results in greater damage, although various factors can influence this outcome. The mechanics of bullet expansion, particularly in hollowpoint bullets, are influenced by both momentum and KE, with faster, lighter bullets potentially offering different performance characteristics compared to heavier bullets.
  • Understanding of basic physics concepts, particularly momentum and kinetic energy.
  • Familiarity with bullet types, specifically hollowpoint bullets.
  • Knowledge of wound ballistics and the factors affecting bullet damage.
  • Awareness of the relationship between force, momentum, and time in the context of firearms.
  • Research the principles of momentum and kinetic energy in ballistics.
  • Explore the mechanics of bullet expansion and its dependence on velocity and mass.
  • Study the effects of different bullet weights on penetration and damage in wound ballistics.
  • Investigate the role of time in force application during bullet impact.
Firearms enthusiasts, ballistics researchers, and anyone interested in understanding the physics behind bullet performance and its implications for damage and recoil.
phil
Good afternoon -please bear with me -I had to skip physics as a subject -so my knowledge is good in some places, non-existant in others.
There was an interesting post in the archives about the momentum of a bullet -that if two bullets impact with the same energy, the one with more momentum will "kick" more?
Momentum is virtually never mentioned in the gun press, but Energy (KE) is a lot -but what does it actually mean? If I shoot something the momentum is what moves the object back -what difference would different levels of energy have? If two bullets have the same momentum, the lighter one will be faster, so have greater KE -what practical effect does that produce?
Related question -a hollowpoint bullet will mushroom when it strikes a liquid/semi-liquid due to a hydraulic effect if the bullet is moving fast enough -is this governed by KE or momentum -is the hollowpoint more likely to open if I make the bullet heavier or make it lighter and faster?
phil
The kick is related to changes in momentum. However you can't be too careful when considering such statements.
Kick is a force. Force is change in momentum per unit time. The same change in momentum will give a different forces when the time during which the change occurs differs.
The rest of your questions concern damage and that's pretty complicated. Basically, all other things equal, more kinetic energy - more damage. But not all things are usually equal
Thanks for the reply
"more energy, more damage"
Main damaging mechanisms of a bullet are the depth and width of the wound channel (there is energy being lost to the stretch cavity -but that produces little damage with handgun rounds) -how does more KE contribute to these? Does more KE mean deeper penetration?
Any ideas on what the forces that mushroom the bullet are?
phil
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 35 ·
