Can a stress tensor be curled in physics?
The discussion centers on the concept of curling a stress tensor in physics, particularly focusing on the mathematical operations applicable to tensor fields. Participants reference Helmholtz's theorem and the Hodge decomposition as frameworks for understanding the curl of tensors, specifically second rank tensors like the stress tensor. The conversation highlights the lack of a direct equivalent to the curl operation for tensors, while suggesting that generalizations exist through the use of antisymmetrized derivatives and induced connections in general relativity. Key insights include the relationship between curl operations and the properties of bilinear tensors.
  • Understanding of tensor calculus, particularly second rank tensors.
  • Familiarity with Helmholtz's theorem and its implications in vector calculus.
  • Knowledge of Hodge decomposition and its application to p-forms.
  • Basic concepts of Riemannian and Lorentzian manifolds in differential geometry.
  • Research the mathematical definition and properties of bilinear tensors.
  • Explore the implications of Helmholtz's theorem in higher-dimensional spaces.
  • Study the Hodge decomposition in the context of Riemannian manifolds.
  • Investigate the role of antisymmetrized derivatives in electromagnetism and general relativity.
Physicists, mathematicians, and students studying advanced topics in tensor calculus, general relativity, and differential geometry will benefit from this discussion.
touqra
Can we curl a stress tensor? What physically meaning will it be?
The term "curl" usually applies to vector fields. If there is an equivalent definition of curl for tensor fields, I am not familair with it.
- Warren
Are you referring to an operation like
\nabla_{[a}T_{b]c?
I was thinking of something like Helmholtz's theorem, where if you specify the div and curl of a vector field, you then know everything there is to know about the field.
Maybe there's something similar for rank 2 tensor, like the stress tensor, or higher tensors.
- Warren
Incidentally, the defn of curl resembles the antisymmetrized derivative (F in electromagnetism & the curvature tensor in GR). That's not accidental, is it?
Hi
i think that the rotor (curl) of a bilinear tensor T can be defined as follows:
let [T] be the matrix associated with T :
t11 t12 t13
[T] = t21 t22 t23
t31 t32 t33
interpreting the raws of [T] as vectors
T1=t11*e1+t12*e2+t13*e3 => [T1]'=(t11,t12,t13)
T2=t21*e1+t22*e2+t23*e3 => [T2]'=(t21,t22,t23)
T3=t31*e3+t32*e2+t33*e3 => [T3]'=(t31,t32,t33)
we can write [T] as
[T1]'
[T] = ( [T2]' )
[T3]'
then, the rotor (curl) of T is simply :
[rotT] = ( [rotT1] , [rotT2] , [rotT3] )
where [rotT1] , [rotT2] , [rotT3] are the column matrix of the rotor (curl) of vectors T1, T2 and T3
Indeed, Thrice, this is not accidental. I am learning much of the nature of axial vectors, curl, and the Minkowski tensor. I need to understand the forms expressed in spherical terms and fields for magnetism.
Curl and all that
touqra said:
Can we curl a [second rank] tensor?
There are various things one could mean by this, but yes, there are various ways of generalizing the "curl" from vector calculus. In the context of gtr, one particularly useful formalism involves "curl" and "div" operations on hyperslices using the induced connection in the slice.
You should ask yourself if your proposed operation yields a tensor.
Yes indeed, the Hodge decomposition, which applies to p-forms, generalizes the Helmholtz decomposition. This can be stated in various ways: one statement is that any exterior form on a compact boundaryless Riemannian manifold can be uniquely decomposed (as an orthogonal direct sum) as the sum of an exact form, a coexact form, and a harmonic form: \beta = d\alpha + \delta \gamma + \eta, where \alpha is a coclosed (p-1)-form, \gamma is a closed (p+1)-form, and \eta is a harmonic p-form (thus, both closed and coclosed).
Undergraduate courses which mention the Helmholtz decomposition typically omit mention of the harmonic term by adding the additional assumption that the form to be decomposed asymptotically vanishes far from the origin (of R^3), whence by Liouville's theorem we expect the harmonic form appearing in the decomposition to vanish, which it does. See for example Frankel, Geometry of Physics.
Exterior forms are anti-symmetric tensors, so this won't apply directly to a symmetric tensor. Also, Hodge theory works best in Riemannian manifolds, not Lorentzian manifolds.
  • · Replies 23 ·
  • · Replies 18 ·
