Do take a look at paragraph 2.11.6 in
http://www.ctan.org/tex-archive/info...ish/lshort.pdf
Besides that, i made a tex document with a bunch of tables and tabulars. they are not all pretty, and some text is in danish. But if you compile it, and watch the output together with the input then you can properly use it to figure out how to make your own.
Code:
\documentclass[article,oldfontcommands]{memoir}
\usepackage{amsmath} %needed for \boldsymbol etc.
\usepackage{array} %needed for m{1.5cm} etc.
\usepackage[collision]{chemsym} %needed for $\C_6\H_5\Br$ etc.
\newcommand{\ket}[1]{\, |#1\rangle}
\newcommand{\bra}[1]{\langle #1 |\,}
\newcommand{\X}{\mathbf{X}}
\begin{document}
\begin{table}[htbp]
\centering
\begin{tabular}[c]{c}
\begin{tabular}{|c|cc|}
\hline
\bf Temperatur & \bf Iltforbrug (STPD) & \bf RQ \\
\hline
\hline
0 & 185 & 0,55 \\
0 & 178,4 & 0,55 \\
10 & 385,79 & 0,71 \\
18 & 837 & 0,4 \\
18 & 755 & 0,21 \\
30 & 1240 & 1 \\
30 & 1760,6 & 0,16 \\
\hline
\end{tabular}
\end{tabular}
\caption{Klassens resultater.}
\label{tab:RQ}
\end{table}
\begin{tabular}{||rccc||}
\hline
\rule{0pt}{10pt} & $\C_6\H_5\Br$ & $\Mg$ & $\C_6\H_5\Mg\Br$ \\
\hline
\hline
\rule{0pt}{10pt} M$_w$ : & $156,9$ mol g$^{-1}$ & $24,3$ mol g$^{-1}$ & $181,2$ mol g$^{-1}$\\
\rule{0pt}{10pt} m : & $9,9$ g & $1,35$ g & \\
\rule{0pt}{10pt} n : & $0.063$ mol & $0,055$ mol & $0,055$ mol \\
\hline
\hline
\rule{0pt}{10pt} & $(\C_6\H_5)_3\C\O\O\C\H_3$ & $(\C_6\H_5)_3\C\O\Mg\Br$ & $(\C_6\H_5)_3\C\O\H$ \\
\hline
\hline
\rule{0pt}{10pt} M$_w$ : & $135,98$ mol g$^{-1}$ & $363,19$ mol g$^{-1}$ & $259,99$ mol g$^{-1}$ \\
\rule{0pt}{10pt} m : & $3,5$ g & & $7,28$ g \\
\rule{0pt}{10pt} n : & $0,028$ mol & $\sim 0,028$ mol & $\sim 0,028$ mol \\
\hline
\end{tabular}
\begin{center}
\begin{tabular}{||l|c|c||}
\hline
\rule{0pt}{10pt} & {\bf Fundet} & {\bf Teoretisk}\\
\hline
\hline
\rule{0pt}{15pt} Udbytte: & 1,29~g (17\%) & 7.28~g\\
\rule{0pt}{15pt} Mp: & 156-57$^{\circ}$C & 157-59$^{\circ}$C\\
\hline
\end{tabular}
\end{center}
\begin{table}[ht]
\centering
\begin{tabular}{|c|c|}
\hline
\rule{0pt}{10pt} {\bf Vand} & \\
\hline
\hline
\rule{0pt}{10pt}
Volumen & $2\cdot 10^{-6}$ m$^3$ $\pm$ $5\cdot 10^{-7}$ m$^3$ \\
Antal dråber & 44 $\pm$ $0$ \\
$\gamma$ & $3.2\cdot 10^{-2}$ N m$^{-1}$ $\pm$ $8\cdot 10^{-3}$N m$^{-1}$\\
\hline
\hline
\rule{0pt}{10pt} {\bf Ethanol} & \\
\hline
\hline
\rule{0pt}{10pt}
Antal dråber & 99 $\pm$ $10$ \\
$\gamma$ & $1.5\cdot 10^{-2}$ N m$^{-1}$ $\pm$ $4\cdot 10^{-3}$N m$^{-1}$\\
\hline
\end{tabular}
\caption{Måleresultater af opsamlet volumen og antal dråber, og den Excel beregnede $\gamma$.}
\label{tab:draabedannelse.maalinger}
\end{table}
\begin{table}[ht]
\centering
\begin{tabular}{|r|r|}
\hline
$\boldsymbol{\gamma}$ & \\
\hline
\hline
\rule{0pt}{10pt}
Vand & $7.3\cdot 10^{-2}$ N M$^{-1}$ \\
Ethanol & $2.3\cdot 10^{-2}$ N M$^{-1}$ \\
\hline
\end{tabular}
\caption{Tabel værdierne for $\gamma$}
\label{tab:draabedannelse.tabel}
\end{table}
\begin{tabular}{rrr|rr|r}
\hline
$m$ & $l$ & $i$ & $\tau_\text{tot}=\tau+\tau_0$ & $\tau_B=B\mu$ & $\tau_B-\tau_\text{tot}=0$ \\
\hline
0.008 & 0.1 & 1.6 & 0.00873 & 0.0088 & 0.00007 \\
0.008 & 0.07 & 1.12 & 0.00637 & 0.00616 & -0.0002 \\
0.004 & 0.1 & 0.88 & 0.00480 & 0.00484 & 0.00004 \\
0.004 & 0.07 & 0.64 & 0.0036 & 0.00352 & -0.00011 \\
\hline
\end{tabular}
\begin{table}[htbp]
\centering
\begin{tabular}{m{1.5cm} m{2.5cm} m{2.5cm}}
\toprule
& $E>V$ & $E<V$ \\
\midrule
$\psi>0$: & curv-down.eps & curv-up.eps\\
$\psi<0$: & curv-up.eps & curv-down.eps\\
\bottomrule
\end{tabular}
\caption[Curvature of the wave function]{Curvature of the wave function.}
\label{tab:curvatire}
\end{table}
\begin{table}[htbp]
\centering
\begin{tabular}{lcccc}
\toprule
& Finite well & Infinite well & Harmonic potential & Triangle potential\\
\midrule
$\varepsilon_0$ & 1.891 & 2.467 & 0.499 & 0.396\\
$\varepsilon_1$ & 7.525 & 9.87 & 1.499 & 0.759\\
$\varepsilon_2$ & 16.767 & 22.2 & 2.499 & -\\
$\varepsilon_3$ & 29.286 & 39.48 & 3.499 & -\\
$\varepsilon_4$ & 44.035 & 61.69 & 4.499 & -\\
\bottomrule
\end{tabular}
\caption[Energies for the wave function in several potentials]{The energies for the finite and infinite square well potentials, the harmonic oscillator potential and the triangle potential, $\alpha=1/10$ in dimensionless units.}
\label{tab:energies-fin-inf-wells}
\end{table}
\begin{table}[htbp]
\centering
\begin{tabular}{lcc}
\toprule
\textbf{The Ground State:} & Finite well potential & Harmonic potential \\
\midrule
$f(\X) = \exp(-\beta \X^2)$ & 2.15 & 0.499 \\
$ f(\X) = \exp(-\beta |\X|)$ & 4.48 & 0.676 \\
$f(\X) = \cos(\beta \X)$ & 2.23 & 0.57 \\
The real wave function & 1.89 & 0.499 \\
\bottomrule
\end{tabular}
\caption[Variational results for the ground state of two potentials]{Variational results for the ground state of the finite well and the harmonic potential.}
\label{tab:variational}
\end{table}
\begin{table}[htbp]
\centering
\toprule
\textbf{The 1st Excited State:} & Finite well potential & Harmonic potential \\
\midrule
$f(\X) = \X\exp(-\beta \X^2)$ & 8.201 & 1.495 \\
$ f(\X) = \X\exp(-\beta |\X|)$ & 11.89 & 1.718 \\
$f(\X) = \X\cos(\beta \X)$ & 8.594 & 1.768 \\
The real wave function & 7.525 & 1.499 \\
\bottomrule
\end{tabular}
\caption[Variational results for the first excited state of two potentials]{Variational results for the first excited state of the finite well and the harmonic potential.}
\label{tab:variational-1}
\end{table}
\begin{table}[tb]
\centering
\begin{adjustwidth*}{-1.1in}{}
\begin{tabular}{ccccccccc}
\toprule
& & & $V_0= 2$ & & & $V_0= 5$ & & \\
\midrule
$\ket{n}$ & \multicolumn{ 2}{c}{Unperturbed Energy} & $\ket{n}$ & Perturbed & Exact & $\ket{n}$ & Perturbed & Exact \\
\midrule
0 & \multicolumn{ 2}{c}{1.890850495} & 0 & 2.68774062 & 2.6907607 & 0 & 3.75858678 & 3.74204499 \\
1 & \multicolumn{ 2}{c}{7.525078075} & 1 & 7.64143918 & 7.6451436 & 1 & 7.80645899 & 7.81253356 \\
2 & \multicolumn{ 2}{c}{16.76700317} & 2 & 17.4082279 & 17.402530 & 2 & 18.4941864 & 18.4413390 \\
3 & \multicolumn{ 2}{c}{29.28589643} & 3 & 29.7700256 & 29.626278 & 3 & 30.5057413 & 30.1160255 \\
4 & \multicolumn{ 2}{c}{44.03462731} & 4 & 44.3988388 & 44.378844 & 4 & 44.9455238 & 44.9274800 \\
\toprule
$V_0= 10$ & & & $V_0= 20$ & & & $V_0= 40$ & & \\
\midrule
$\ket{n}$ & Perturbed & Exact & $\ket{n}$ & Perturbed & Exact & $\ket{n}$ & Perturbed & Exact \\
\midrule
0 & 5.21135958 & 5.13244619 & 0 & 6.87201475 & 6.9024154 & 0 & 5.21376331 & 8.49850996 \\
1 & 8.05610043 & 8.06184361 & 1 & 8.46016486 & 8.4714451 & 1 & 8.88741995 & 9.05153551 \\
2 & 20.6351080 & 20.3479315 & 2 & 26.1581661 & 24.355128 & 2 & 42.1691413 & 30.6668117 \\
3 & 31.7573257 & 30.8782262 & 3 & 34.3557130 & 32.212670 & 3 & 39.9333613 & 34.2528377 \\
4 & 45.8576454 & 45.9342207 & 4 & 47.6855645 & 48.269748 & 4 & 51.3561050 & --- \\
\bottomrule
\end{tabular}
\end{adjustwidth*}
\caption[Numerical results for the perturbation method and the shooting method]{Numerical results for the energies obtained by the perturbation method and exact values by the shooting method for perturbations.}
\label{tab:perturb-calulations}
\end{table}
\begin{table}[htbp]
\centering
\begin{adjustwidth*}{0in}{-0.9in}
\toprule
$V_0=2$ & & & $V_0=10$ & & & $V_0=40$ & & \\
\midrule
$\ket{n}$ & 1st order & 2nd order & $\ket{n}$ & 1st order & 2nd order & $\ket{n}$ & 1st order & 2nd order \\
\midrule
0 & 2.72093770 & 2.68774062 & 0 & 6.04128654 & 5.21135958 & 0 & 18.4925947 & 5.21376331 \\
1 & 7.64397833 & 7.64143918 & 1 & 8.11957939 & 8.05610043 & 1 & 9.90308336 & 8.88741995 \\
2 & 17.3751288 & 17.4082279 & 2 & 19.8076315 & 20.6351080 & 2 & 28.9295167 & 42.1691413 \\
3 & 29.7674865 & 29.7700256 & 3 & 31.6938468 & 31.7573257 & 3 & 38.9176979 & 39.9333613 \\
4 & 44.3987408 & 44.3988388 & 4 & 45.8551950 & 45.8576454 & 4 & 51.3168983 & 51.3561050 \\
\bottomrule
\end{tabular}
\end{adjustwidth*}
\caption{Perturbation results for the energies $E_n$, calculated to first and second order.}
\label{tab:perturb-calulations-order-corrections}
\end{table}
\begin{table}[htbp]
\begin{tabular}{cccc}
\toprule
$\ket{n}$ & Exact & Perturbed & Matrix \\
\midrule
0 & 7.990295595 & 8.00316575 & 8.003312 \\
1 & 8.572961234 & 8.57098177 & 8.571135 \\
\midrule
& \multicolumn{ 3}{l}{$E_0 = 8.28722344$} \\
& \multicolumn{ 3}{l}{$S \;\, = 0.02069867$} \\
& \multicolumn{ 3}{l}{$V' = \bra{\psi_\ell}V_r-V_0\ket{\psi_r} = -0.283911104$} \\
& \multicolumn{ 3}{l}{$\phantom{V' =\;}\bra{\psi_\ell}V_r-V_0\ket{\psi_\ell} \,= -0.006026201$}\\
\bottomrule
\end{tabular}
\caption{Energies for the double well potential.}
\label{tab:double-well-energies}
\end{table}
\begin{table}[htbp]
\begin{tabular}{lcccccc}
\toprule
Number of wells & $\ket{n}$& & & & & \\
\midrule
2 & 0th & + & + & & & \\
& 1st & + & -- & & & \\
\midrule
3 & 0th & + & + & + & & \\
& 1st & + & 0 & -- & & \\
& 2nd & + & -- & + & & \\
\midrule
4 & 0th & + & + & + & + & \\
& 1st & + & + & -- & -- & \\
& 2nd & + & -- & -- & + & \\
& 3rd & + & -- & + & -- & \\
\midrule
5 & 0th & + & + & + & + & + \\
& 1st & + & + & 0 & -- & -- \\
& 2nd & + & 0 & -- & 0 & + \\
& 3rd & + & -- & 0 & + & -- \\
& 4th & + & -- & + & -- & + \\
\bottomrule
\end{tabular}
\caption[Signature of the wave functions in multiple wells.]{Signature of the wave functions in multiple wells. The curvature is positive in (+), negative in (-) and zero in (0).}
\label{tab:signature-multiple-wells}
\end{table}
\begin{table}[htbp]
\centering
\begin{tabular}{lccclccc}
\toprule
No. of wells & $\ket{n}$ & Exact & Matrix & No. of wells & $\ket{n}$ & Exact & Matrix \\
\midrule
3 & 0 & 7.87161719 & 7.88571251 & 4 & 0 & 7.81462248 & 7.82784563 \\
& 1 & 8.27250702 & 8.28722345 & & 1 & 8.09220791 & 8.11175673 \\
& 2 & 8.69529213 & 8.68873438 & & 2 & 8.45166881 & 8.46269016 \\
& -- & -- & -- & & 3 & 8.75700426 & 8.74660126 \\
\midrule
\midrule
5 & 0 & 7.78325035 & 7.79547499 & 6 & 0 & 7.76422927 & 7.77563331 \\
& 1 & 7.98349286 & 8.00331234 & & 1 & 7.91446488 & 7.93319209 \\
& 2 & 8.26761563 & 8.28722345 & & 2 & 8.13832688 & 8.16087112 \\
& 3 & 8.56508893 & 8.57113455 & & 3 & 8.39690368 & 8.41357577 \\
& 4 & 8.79213105 & 8.77897190 & & 4 & 8.63982438 & 8.64125480 \\
& -- & -- & -- & & 5 & 8.81393242 & 8.79881358 \\
\midrule
\midrule
7 & 0 & 7.75185864 & 7.76262413 & 8 & 0 & 7.74336892 & 7.75364511 \\
& 1 & 7.86829119 & 7.88571251 & & 1 & 7.83614993 & 7.85224640 \\
& 2 & 8.04708325 & 8.06992729 & & 2 & 7.98126001 & 8.00331234 \\
& 3 & 8.26518034 & 8.28722345 & & 3 & 8.16443872 & 8.18862215 \\
& 4 & 8.49179660 & 8.50451960 & & 4 & 8.36609476 & 8.38582474 \\
& 5 & 8.69115742 & 8.68873438 & & 5 & 8.56241882 & 8.57113455 \\
& 6 & 8.82835783 & 8.81182276 & & 6 & 8.72774422 & 8.72220049 \\
& -- & -- & -- & & 7 & 8.83838104 & 8.82080179 \\
\bottomrule
\end{tabular}
\caption[Energies for multiple well potentials.]{Energies for the several multiple well potentials. Calculated exact by the shooting method and by the matrix method eq.~(??).}
\label{tab:multiple-well-energies}
\end{table}
\begin{table}[htbp]
\centering
\begin{tabular}{lccccccccccc}
\toprule
Number of wells & $\ket{n}$ & & & & & & & & & & \\
\midrule
6 & 1st & + & + & + & + & + & + & & & & \\
& 2nd & + & + & + & -- & -- & -- & & & & \\
& 3rd & + & + & -- & -- & + & + & & & & \\
& 4th & + & -- & -- & + & + & -- & & & & \\
& 5th & + & -- & + & + & -- & + & & & & \\
& 6th & + & -- & + & -- & + & -- & & & & \\
\midrule
7 & 1st & + & + & + & + & + & + & + & & & \\
& 2nd & + & + & + & 0 & -- & -- & -- & & & \\
& 3rd & + & + & -- & -- & -- & + & + & & & \\
& 4th & + & 0 & -- & 0 & + & 0 & -- & & & \\
& 5th & + & -- & -- & + & -- & -- & + & & & \\
& 6th & + & -- & + & 0 & -- & + & -- & & & \\
& 7th & + & -- & + & -- & + & -- & + & & & \\
\midrule
8 & 1st & + & + & + & + & + & + & + & + & & \\
& 2nd & + & + & + & + & -- & -- & -- & -- & & \\
& 3rd & + & + & 0 & -- & -- & 0 & + & + & & \\
& 4th & + & + & -- & -- & + & + & -- & -- & & \\
& 5th & + & -- & -- & + & + & -- & -- & + & & \\
& 6th & + & -- & 0 & + & -- & 0 & + & -- & & \\
& 7th & + & -- & + & -- & -- & + & -- & + & & \\
& 8th & + & -- & + & -- & + & -- & + & -- & & \\
\midrule
9 & 1st & + & + & + & + & + & + & + & + & + & \\
& 2nd & + & + & + & + & 0 & -- & -- & -- & -- & \\
& 3rd & + & + & + & -- & -- & -- & + & + & + & \\
& 4th & + & + & -- & -- & 0 & + & + & -- & -- & \\
& 5th & + & 0 & -- & 0 & + & 0 & -- & 0 & + & \\
& 6th & + & -- & -- & + & 0 & -- & + & + & -- & \\
& 7th & + & -- & + & + & -- & + & + & -- & + & \\
& 8th & + & -- & + & -- & 0 & + & -- & + & -- & \\
& 9th & + & -- & + & -- & + & -- & + & -- & + & \\
\bottomrule
\end{tabular}
\end{table}
\end{document}
Also a quick google search on 'latex tabular tutorial' gave as a first result this tutorial:
http://www.andy-roberts.net/misc/lat...tutorial4.html
