How Relativity Connects Electric and Magnetic Fields
nathan.br
Hi,
I came to the following article, and I have a questions about it:
http://galileo.phys.virginia.edu/classes/252/rel_el_mag.html
From this article, it seems that if the electric current is not flowing in a wire, but instead in vacuum there will be no repelling force (since there is no background positive charge). If there is no repelling force, what we call magnetic field in the wire frame of reference will not exist.
Can I conclude that an electric current does not create a magnetic field if it is flowing in vacuum?
When you remove the wire and its positive charges, in the second frame you do eliminate the electric field that the positive charges produce. However, in the first frame (the "wire frame") you now have to take into account the electric field that the negative charges produce!
The electric field produced by the negative charges has a different magnitude in the two frames, because the charge density is different in the two frames.
nathan.br said:
Hi,
I think that the game with infinitely long wires is counterproductive. Have a look at JEMWA 20 No.9 1189 2006 "Relativistic derivations of electric and magnetic fields generated by an electric point charge moving with constant velocity"
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
