Rotational Kinetics hardest problem
The discussion centers on a problem involving the rotational kinetics of a ceiling fan's blades, which have a radius of 0.375 m and an initial angular velocity of +1.95 rad/s, with an angular acceleration of +2.69 rad/s² after the speed is increased. Participants express confusion about how to calculate the total acceleration and the angle between total and centripetal acceleration. It is clarified that the blade tips experience both centripetal acceleration and tangential acceleration due to the changing speed. The solution involves finding these two components of acceleration and using them to determine the resultant acceleration and the angle between it and the centripetal acceleration. Understanding these concepts is crucial for solving the problem effectively.
shaka23h
Multiple-Concept Example 7 explores the approach taken in problems such as this one. The blades of a ceiling fan have a radius of 0.375 m and are rotating about a fixed axis with an angular velocity of +1.95 rad/s. When the switch on the fan is turned to a higher speed, the blades acquire an angular acceleration of +2.69 rad/s2. After 0.473 s have elapsed since the switch was reset, what is (a) the total acceleration (in m/s2) of a point on the tip of a blade and (b) the angle between the total acceleration and the centripetal acceleration (See Figure 8.13b)?
I am very lost on this problem.
THe example pretty much just told me that
a = Sqrt ac^2 + aT^2
I have no clue how to begin this problem. please help even if its just a hint.
THanks
THanks
We are going to have to agree on an interpretation of the given information. I assume they mean the the tips of the blades of the fan are .375m from the center of the axis or rotation. Let's just call that R. There is a connection between the angular velocity of the blades, and the speed that a blade tip is moving. Since there is an angular acceleration for some period of time, the angular velocity will be increasing and will reach a new value at the end of the specified time. At that time, the blade tip speed is still increasing, but has a new value that can be calculated from the given information.
At the point in question the blade tip has both a speed and a rate of change of speed. The speed has an associated centripetal acceleration directed toward the center of the circle. The rate of change of speed has an associated acceleration in a direction tangent to the circle. Your job, should you choose to accept it, is to find these two components of acceleration and their resultant and find the angle between the total acceleration and the centripetal component.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
