Explaining the Ripple Effect in a Circular Wave Pulse
The discussion focuses on the phenomenon of circular wave pulses generated by disturbances in a liquid, specifically analyzing the relationship between group velocity and phase velocity. The phase velocity of the ripples is defined by the equation v_p = √(2πS/λρ), where S represents surface tension and ρ denotes the liquid's density. The group velocity, calculated as v_g = dω/dk, is slower than the phase velocity, resulting in the observation that individual ripples move inward faster than the overall wave propagates outward. This explains the fine structure of surface ripples within the circular disturbance.
  • Understanding of wave mechanics, specifically group and phase velocity.
  • Familiarity with the equations v_p = √(2πS/λρ) and v_g = dω/dk.
  • Basic knowledge of fluid dynamics, including surface tension and density concepts.
  • Experience with Fourier analysis and wave superposition principles.
  • Research the derivation and implications of group velocity in wave theory.
  • Explore the effects of surface tension on wave propagation in liquids.
  • Study the applications of phase velocity in various wave phenomena.
  • Investigate the role of Fourier analysis in understanding wave superposition and interference.
Students and professionals in physics, particularly those studying wave mechanics, fluid dynamics, and related fields. This discussion is beneficial for anyone seeking to understand the dynamics of wave propagation in liquids.
Mindscrape
Here is the problem:
If a pebbel is tossed into a pond, a circular wave pulse propagates outward from the disturbance. If you look closely you will see a fine structure in the pulse consisting of surface ripples moving inward though the circular disturbance. Explain this effect in terms of group and phase velocity if the phase velocity of ripples is given by [tex]v_p = \sqrt{2 \pi S/ \lambda \rho}[/tex], Where S is the surface tension and p is the density of the liquid.
I am not really sure where to start. Should I find the envelope velocity and compare it to the high frequency velocity. I know it will have something to do with superposition, but Fourier analysis seems like it is the wrong approach.
Can someone help me out here?Answer:The explanation for this effect can be found by considering the group velocity and phase velocity of the wave pulse. The group velocity of a wave is the velocity of the envelope of the wave, and it is given by v_g = \frac{d\omega}{dk}, where \omega is the angular frequency and k is the wavenumber. In contrast, the phase velocity of a wave is the velocity of the individual ripples and it is given by v_p = \sqrt{\frac{2\pi S}{\lambda \rho}}, where S is the surface tension and \rho is the density of the liquid. In this case, since the phase velocity of the ripples is given, we can calculate the group velocity of the wave pulse. We can see that since the group velocity is the velocity of the envelope of the wave, it is slower than the phase velocity. This means that the individual ripples will move inward through the circular disturbance at a faster rate than the wave itself is propagating outward. This is why you can see the fine structure in the pulse consisting of the surface ripples moving inward.
