Understanding Variable Force and Kinetic Energy: Exploring Halliday's Answers
The discussion revolves around solving a physics problem related to variable force and kinetic energy. The initial kinetic energy of a 2.0 kg body moving along the x-axis is 4.0 m/s, and the participants calculate the kinetic energy at various points based on the work done by the force. The correct answers are 12 J for part (a), 4.0 m for part (b), and 18 J for the maximum kinetic energy attained. Participants express confusion over the calculations, particularly regarding the work-energy principle and the interpretation of negative work. The importance of correctly identifying the initial kinetic energy is emphasized in resolving the problem.
mbrmbrg
Behold Halliday's Question and Halliday's answers:
The only force acting on a 2.0 kg body as it moves along the x-axis varies as shown in Figure 7-41 (see attatchment). The velocity of the body at x = 0 is 4.0 m/s.
(a) What is the kinetic energy of the body at x = 3.0 m?
12 J
(b) At what value of x will the body have a kinetic energy of 8.0 J?
4.0 m
(c) What is the maximum kinetic energy attained by the body between x = 0 and x = 5.0 m?
18 J
I am stumped. I've only tried to figure out (a) and (b), but my method does not give me correct answers. My train of thought was that Delta KE=W=area under curve. So for part (a), I said that area under graph is (triangle-triangle-rectangle) = -4 Nm. Well, gee.
Maybe since KE is always positive, take the absolute value of various areas! I think that is very poor reasoning, because Delta KE and W can both be negative. And even when I do that, I get 8 Nm, which is still wrong.
Similar reasoning applied to (b) also gives the incorrect answer, which is comforting.
A hint from the wise gurus perhaps?
Correct.
The change of KE is equal to the work done on the body. If the work is negative, the kinetic energy will decrease. Final KE - initial KE = W. You know the initial KE, (16 J) you know W,(-4 J) what is the problem?
ehild
Problem is that I thought initial Kinetic Energy was 4J. Wups!
Thank you.
I'm doing the same problem. Does anyone know the answers?
I got 12J for (a) but I'm lost on (b) and (c)
Edit: this is what I got after some thought...
(a) 12 J
(b) x=4
(c) 28 J
anyone agree?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
