Thread Closed
Input/Output voltage relationship for alternator
Share Thread Thread Tools
Nov5-06, 02:07 PM   #1
Smile
Hello again,
I'm here with a request for some advice. Hopefully I won't need as much this time as it's something I'm a bit more clued up on
I'm trying to work out what output voltage will occur on the stator coils of my alternator in relation to the excitation voltage in the rotor coils.
I can obtain data such as windings per pole, resistance of coil, rpm and others because I have direct access to it.
Before I go steaming off down what would surely turn-out to be the long way round does anyone have an idea for a good acceptably accurate solution?
I was thinking of working out the strength of the magnetic field in the rotor for given excitation voltages and working out how many times it passed through the poles on the stator for various rpm's. Would this be a good way to start?
Bear in mind I'm only looking for a reasonably accurate approximation, not something ultra accurate
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Nov5-06, 08:06 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Back EMF seems like it would be a consideration.
Certainly a factor in motors.
Don't know how it applies to generators.
Nov6-06, 10:20 AM   #3
I suppose given that both rotor and stator coils are basically large inductors this would indeed be an issue. Thanks for pointing it out
Thread Closed
Thread Tools
Similar Threads for: Input/Output voltage relationship for alternator
Thread Forum Replies
Input & Output Impedance Engineering, Comp Sci, & Technology Homework 14
how to get output voltage from the tachometer output Engineering Systems & Design 1
Deriving input-output relationship General Physics 4
Car Alternator output General Engineering 2
input/output question General Engineering 9
