Recovering SE from Path integral
The discussion revolves around the derivation of the Schrödinger equation (SE) from the path integral formulation of quantum mechanics. Participants explore various aspects of this topic, including the relationship between the propagator and the action, known solutions for different systems, and advanced methods such as semiclassical expansions and Wick rotation.
  • Some participants note the relationship between the propagator and the action, suggesting that the propagator can be expressed in terms of the action through the equation provided.
  • One participant argues that while deriving the SE from the path integral approach is straightforward, solving problems using path integrals is often easier than solving ordinary differential equations (ODEs) associated with the SE.
  • Another participant highlights the nontrivial nature of both the SE and path integral formulations, mentioning specific known solutions for the SE, such as those for free particles and harmonic oscillators, and questioning the existence of additional solutions for the path integral formulation.
  • A participant introduces the concept of semiclassical expansion, mentioning its connection to the Hawking effect and the challenges in summing the series for non-zero values of hbar.
  • There is a discussion about the use of Wick rotation and Monte Carlo integration methods in evaluating path integrals, with some participants expressing skepticism about the availability of analytical solutions through these methods.
  • One participant provides a derivation of the time-dependent Schrödinger equation from the propagator, linking it to classical mechanics and energy considerations.
Participants express differing views on the ease of solving problems using path integrals compared to traditional methods. There is no consensus on the completeness of known solutions for the path integral formulation, and the discussion remains unresolved regarding the effectiveness of advanced methods like Wick rotation.
Some claims rely on specific definitions and assumptions, such as the nature of the action and the conditions under which certain solutions are valid. The discussion also touches on unresolved mathematical steps related to semiclassical expansions and the applicability of numerical methods.
Karlisbad
I know someone posted it before..but i would like to know if given the factor:
[tex]e^{(i/\hbar)S[\phi]}[/tex] (1)
and knowing the progpagator satisfies:
[tex]\Psi (x2,t2)=\int_{-\infty}^{\infty}dxdtK(x2,t2,x1,t1)\Psi(x1,t1)[/tex]
Where S is the action and the propagator is related to (1)
:zzz:
A derivation of SE' from path integral approach to QM is to be found in any decent text on quantum mechanics. It's not a big deal.
However, solving problems with path integral rather than solving ODE's (required by writing SE's in the position representation) is (a big deal), since it's usually easier.
Daniel.
Daniel.
I would definitely argue that solving the Schrödinger equation or the path integral is both nontrivial in most cases. I'm curious about known solutions for the Schrödinger equation versus the path integral...
For the Schrödinger equation, I know there are solutions to the free particle, harmonic oscillator, V~r potential, V~1/r potential, and that the hydrogen atom has been solved exactly in a constant magnetic field (although I don't remember where I saw this...).
For the path integral formulation, free particle and harmonic oscillator are solved (this is in any book that deals extensively with path integrals), as well as the hydrogen atom (this is not).
Does anybody know of other existing solutions?
- "Semiclassical expansion"------> You expand the action [tex]S[\phi][/tex] of the field near its classical solution so [tex]\delta S[\phi _{classical}]=0[/tex] i don't know who proved it, i heard about that "Hawking effect" or other Pseudo-Quantum Gravity models were based on this expansion..the corrections to the WKB approach can be taken:
[tex]\sum_{n=1}^^{\infty}a(n,r,t)(\hbar ^{n})^{n}[/tex]
Unfortunately we can't sum the series for any h except h=0 since it diverges...:frown: :frown: in any case if we could take the sum then we could find an EXACT method to evaluate path integrals.
- More complicate methods?..well they told in a seminar at my University that under "Wick rotation" and other methods perturbation theory with path integral could be evaluate using infinite-dimensional Montecarlo integration with a Infinite-dimensional Gaussian Meassure (don't ask :redface: )
More complicate methods?..well they told in a seminar at my University that under "Wick rotation" and other methods perturbation theory with path integral could be evaluate using infinite-dimensional Montecarlo integration with a Infinite-dimensional Gaussian Meassure (don't ask)
Yes, Wick rotation makes the integrals amenable to numerical solution but I do not think they give any further analytical solutions.
Try look up anything by Hagen Kleinhert. There are a class of transformations which give a path integral with certain potential a gaussian measure, which is then solvable.
One extra for the SE is the Hookian atom, although this is just a 3d H0.
the propogator is:
[tex]\Psi_f(x,t) = e^{\frac{i}{\hbar}S} \Psi_i(x,t)[/tex]
where we are propagating some initial wavefunction [tex]\Psi_i[/tex]to some final wavefunction [tex]\Psi_f[/tex]
take the derivative with respect to the final time [tex]t_f[/tex]:
[tex]\frac{\partial \Psi_f}{\partial t_f} = \frac{i}{\hbar} \frac{\partial S}{\partial t_f}e^{\frac{i}{\hbar}S} \Psi_i[/tex]
[tex]\frac{\partial \Psi_f}{\partial t_f} = \frac{i}{\hbar} \frac{\partial S}{\partial t_f} \Psi_f[/tex]
there is a result from classical lagrangian mechanics (i won't derive it here, you can look it up in any classical mech. book) that says that [tex]\frac{\partial S}{\partial t_f} = -E_f[/tex] so:
[tex]\frac{\partial \Psi_f}{\partial t_f} = -\frac{i}{\hbar} E_f \Psi_f[/tex]
[tex]i \hbar \frac{\partial \Psi_f}{\partial t_f} = E_f \Psi_f[/tex]
which of course is the time-dependent Schrödinger equation
  • · Replies 0 ·
