Electrical= Resistance and Energy
A wire with a resistance of 9.0 ohms is connected to a 3.0 V battery with an internal resistance of 1.0 ohm. The energy transferred from chemical to electrical form in 4.0 minutes is calculated to be 216 joules. The initial calculation for thermal energy in the wire was incorrect at 189.629 joules, prompting a discussion about the impact of the battery's internal resistance on the overall circuit. The correct thermal energy calculation, considering the internal resistance, led to a revised answer of 194.4 joules. The importance of accounting for the battery's resistance in energy calculations was emphasized in the discussion.
Forceflow
A wire of resistance 9.0 is connected to a battery whose emf is 3.0 V and whose internal resistance is 1.0 .
(a) How much energy is transferred from chemical to electrical form in 4.0 min?
(b) How much energy appears in the wire as thermal energy in that time?
answer to a= 216 (that's correct)
for b, i got 189.629 (that one is wrong though)
For the work, i did: I= 3V/9 = .3333 A
Vtotal= 3V-IR
Vtotal= 3V-.333(1)
Vtotal= 2.6666
p=Vsquared/R
P=2.666 squared/9
P= .79011
.79011 (4) (60) = 189.62
When calculating the current -- why would you ignore the resistance of the battery? (Normally you would, but in this case it is a fairly high component of the overall resistance of the circuit)
i would ignore it because its asking for the energy in the wire specifically..i believe anyway
if for a new answer, i got 194.4 joules..would that be correct?
is 194.4 the answer?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
