Quantum Questions: Applying Primes, Differentiability, Probability & More
  • Thread starter Thread starter paul_peciak
    Quantum
The discussion explores the application of arbitrarily large prime numbers in mathematical limits and their relationship with differentiation and differentiability, concluding that there is no connection due to their discrete versus continuous nature. It also addresses the role of probability in mathematical analysis, emphasizing that measure theory is crucial for understanding probability, especially in infinite sample spaces. The conversation highlights the need for foundational knowledge in calculus before tackling these advanced topics. Additionally, there is speculation about the connection between prime numbers and eigenvalues, suggesting that primes may represent discrete eigenvalues in mathematical frameworks. Overall, the thread emphasizes the complexity of these concepts and the necessity for a solid mathematical foundation.
paul_peciak
Hi,
How can arbitrarily large primes be applied to limit
Is there any connection between an infinite set limit like prime numbers and differentiation and differentiability?
x(infinite set of possible variables) would change with respect to y(infinite set of possible variables) on which it has a functional relationship.
Also where does probability play specifically in mathematical analysis? In probability theory what happens when the sample space is infinite ? I have been trying to make sense of this with Fourier transform and measure theory of infinite intersections/ unions. Does anyone have any links that I can use to familiarize myself more with these concepts? Thanks in advance.
:rolleyes:
Mathematics news on Phys.org
It's hard to see exactly what you are asking. The fact that you titled this "quantum questions" when there is nothing about quantum physics in it!
"How can arbitrarily large primes be applied to limit"
I have no idea what you mean by applying anything "to limit". If you mean "finding the limit of a sequence", restricting yourself to a subset of the natural numbers won't help. What happens on the composite numbers may be key to the problem.
"Is there any connection between an infinite set limit like prime numbers and differentiation and differentiability? "
Since the former is discrete and the latter continuous, none at all.
"x(infinite set of possible variables) would change with respect to y(infinite set of possible variables) on which it has a functional relationship. "
The fact that the domain is infinite is not relevant- it has to be continuous.
"Also where does probability play specifically in mathematical analysis? "
None whatsoever. Mathematical analysis (in particular measure theory plays a major role in probability.
"probability theory what happens when the sample space is infinite ?"
Not a problem. You need to define a "probabilty density" and integrate over the relevant sets.
" I have been trying to make sense of this with Fourier transform and measure theory of infinite intersections/ unions."
Your first few questions don't seem to indicate that you know even basic calculus. Learn that first!
(Hmm- discrete versus continuous- could this be--- )
On the topic of prime numbers, I think have similarly been thinking about how they seem to mimic eigenvalues or eigen functions or a statespace. Eigen functions are those functions that undergo no transformation when an operator is applied to them (whether this is a Hamiltonian or a momentum operator) is largely irrelevant. Prime numbers seem to be special from this perspective. I also came across a paper that proved that you can scale Energy levels in a harmonic oscillator to fit into the distribution of prime numbers. This hints at a deeper connection between numbers in general as representing a set of discrete eigen values.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
