Solving an Unexpected Problem: Newton's Third Law
The discussion revolves around a problem involving two current-carrying wires and whether Newton's third law is violated. The initial analysis suggests that the force on wire 1 due to wire 2 is zero, leading to the conclusion that the law is violated. However, it is clarified that this interpretation is incorrect because the magnetic field from an infinitesimal current element cannot be considered in isolation. The correct approach involves understanding the net forces on infinitely long wires, which ultimately show that Newton's third law holds true. The problem requires a more comprehensive analysis of the magnetic interactions between the wires.
gazepdapi1
my professor kind of sprung this problem out of nowhere for the class, and I'm having just a little trouble getting started? The problem goes like this:
A current wire pointing in the +j direction has an Idl. A second current wire in the +i direction has a different Idl.
The question he proposed was, is Newtons third law violated?
http://img241.imageshack.us/img241/7699/untitledxy4.jpg
for the bottom wire the 2's should be one's, my mistake.
Can anyone give me a hint?
Can you restate the problem?
Here's a new picture of the problem, the first one was not drawn correctly.http://img110.imageshack.us/img110/9952/untitledey8.jpg
The question is, given the two current elements as shown above, with current in the direction of the arrow, is Newtons third law violated. This is what I got. B on 2 due to 1 is in the (+k) direction given by the right hand rule. F on 2 due to B on 1 = I2dl2 X B1 = I2dl2B1 (+j x +k) = (+i) (the numbers are subscripts and the x's represent cross products. B on 1 dues to 2, is 0 because the current is in the same direction as p, the point where we are trying to measure the B. (dl X r) = 0. Therefore there is no force on 1 due to 2. This means that Newton's third law is violated. But the professor told us that it only appears that it's violated and now we have to prove why its not violated.
Can anyone tell me why? I can't seem to figure it out.
thanks a lot, nertil
nobody knows
This question is ill-posed as written because you can't consider the magnetic field from an infinitesimal current element in isolation. This point is made in every E&M book I'm aware of (see the discussion on the Law of Biot Savart).
If you're being asked to consider two infinitely long wires along i and j directions, of which just a little is pictured, then it's easy to show that the net force on each wire produced by the other is zero, and the third law holds as expected.
As for point P, I don't know what it's supposed to represent in your diagram.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
