How Does Angular Velocity Relate to Centripetal Acceleration?
  • Thread starter Thread starter iamtrojan3
    Centripetal
To achieve a centripetal acceleration of 3 g's at a radius of 2.5 m, the angular velocity (W) must be calculated using the formula W^2R = centripetal acceleration. By substituting the values, W was found to be approximately 3.4 radian/sec. It's important to include units in calculations to verify correctness, as acceleration is measured in m/s^2 and radius in meters. This ensures that the resulting units for W are in 1/s, confirming the calculation is accurate. The discussion emphasizes the significance of unit consistency in physics problems.
iamtrojan3
What angular velocity would cause a centripetal acceleration of 3 g's if the radius were 2.5 m?
i have a test 2moro on this stuff... yea i need to know =D thx
i guess m(v^2)/r or mW^2r
no idea. srry :confused:
What is the W? And what do you calculate with mW^2r?
W is rotational velocity.. sryy for not making that clear.
(MASS)(W^2)(radius)=centripetal Force
W^2R= Centripetal Acceleration
I just plugged numbers in 29.4= W^2(2.5) and i got 3.4radian/sec for W.
this looks 2 easy... if someoen could verify please =D
Yes, very good, your answer is correct. But you should also write down the units, for example acceleration is in m/s^2 and radius in m. This allows you to check whether your result is correct.
For example if you calculated W as something with 1/s^2, you know you made a mistake because the unit must be 1/s (or radian/sec).
thanks tons edgardo!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
