Calculate Wire Bending as Function of Length & Mass
  • Thread starter Thread starter aey248
    Mass Wire
The discussion centers on calculating wire bending as a function of length and mass. It is established that wire bending is influenced by multiple factors beyond just mass, including material properties and geometry. The user successfully reached a valid solution, indicating that the problem can be resolved with appropriate considerations of these factors.
  • Understanding of material properties such as Young's modulus
  • Knowledge of basic physics principles related to bending moments
  • Familiarity with wire geometry and cross-sectional area
  • Experience with mathematical modeling of physical systems
  • Research the relationship between Young's modulus and wire bending
  • Learn about calculating bending moments in beams
  • Explore the effects of wire diameter on bending behavior
  • Investigate mathematical models for predicting deflection in beams
Engineers, physicists, and students studying mechanics of materials or structural analysis will benefit from this discussion.
aey248
please i need an answer for this quation, if i have a wire with mass m, how can i calculate its bending as a function on the length. thanks
You are aware, are you not, that this depends on much more than just the mass!
Thanks I reach to the valid solution, thanks a gain for you.
  • · Replies 17 ·
  • · Replies 20 ·
