| Thread Closed |
The positive feedback factor of CO2 |
Share Thread | Thread Tools |
| Mar26-08, 12:15 AM | #35 |
The positive feedback factor of CO2But if the argument stops there, then this is only at most *suggestive*, and no *proof*: you cannot logically derive the necessity of the CO2 rise by just observing this isotopic marking. Now, if it is part of a more complicated model, then the argument depends on the reliability of the model. In other words, there is no direct link between the amount of CO2 in the atmosphere, the isotopic ratios and an eventual causality of the CO2 from fossil burning onto the rising of the CO2 level. But the way things are formulated often, is that this relation is evident, and that finding a correlation between the isotopic markings and the CO2 level indicates a causal link. Or otherwise, I didn't understand the argument. Of course, that's no proof either that this is NOT the case. It is even such, that without isotopic marking, the CO2 level rise could even be due to fossil fuel burning, if the cycle is fast enough. This indicates even more the looseness of the connection between isotopic ratios and the causality of the fossil fuel burning in the rise of the CO2 level. See, for instance, this is pure speculation on my side of course, but it might be that the reason for the increasing CO2 levels in the atmosphere are due mainly to deforestation - I'm not going to develop that here, as I said, it is just a guess on my part. Deforestation might change the parameters of the carbon cycle, and as such, make the atmosphere settle to another steady-state value, with or without burning of fossil fuels. The observational results would be quite similar if the numbers come out right. Again, I'm just making this up here, I'm not advancing it as a "theory", but just to indicate that *suggestive* evidence (the isotope ratio) is not air-tight proof. Then again, I might misunderstand the whole argument, but that's what I make of it. |
| Mar27-08, 02:41 PM | #36 |
| Jul22-08, 04:29 AM | #37 |
Back to the OP subject
So a complaint was filed against the movie "The Great Global Warming Swindle" about misinformation. Also this CO2 lagging was addressed here: http://www.ofcomswindlecomplaint.net...plaint/p44.htm http://www.ofcomswindlecomplaint.net...plaint/p45.htm http://www.ofcomswindlecomplaint.net...plaint/p46.htm http://www.ofcomswindlecomplaint.net...plaint/p47.htm It may be noted that the complaint does still not address the problems with positive feedback dynamics are indicated here in the OP. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: The positive feedback factor of CO2
| Q factor (Quality Factor) | Introductory Physics Homework | 2 | ||
| What causes the feedback (a noise increasing in intensity and pitch)? | Electrical Engineering | 1 | ||
| Op-amp with feedback | Electrical Engineering | 11 | ||
| Operational Amplifier with positive feedback problems | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Feedback? | Introductory Physics Homework | 1 | ||
