| Thread Closed |
Conductivity |
Share Thread | Thread Tools |
| Apr17-07, 07:13 PM | #1 |
Conductivity
A cylinder with a piston is filled with ideal gas. The gas temperature is held at 450 K. The cylinder is heated by an oven through a square metal rod connected between the oven and the cylinder. The rod has sides d = 1 cm and length L = 2.3 m. (a) If the oven is held at 750 K, and the heat current conducted through the metal rod is 27 W, find the thermal conductivity of the metal in the rod. k = W/m K 9 NO HELP: H = k*A*(T2-T1) / L HELP: H is the heat current; k is thermal conductivity; T2 and T1 are temperatures at two ends; A and L are cross-sectional area and length of the rod. 2. Relevant equations H = k*A*(T2-T1) / L 3. The attempt at a solution 27=k(.023m^2)(300k)/2.3m k=9 I'm pretty sure im right here... the following quesion asks, For a larger cylinder at 450 K, a heat current of 57 W is needed. If we use the same metal rod to conduct heat, find the oven temperature in Kelvin that will maintain the necessary heat current. and i used the k value 9 and gave me an answer 1083.3, which was the correct answer... |
| Apr18-07, 01:19 PM | #2 |
looks right.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Conductivity
| Conductivity of solutions | Biology, Chemistry & Other Homework | 23 | ||
| Hi I have lost my Conductivity notes | Chemistry | 0 | ||
| Conductivity of Ne | Atomic, Solid State, Comp. Physics | 6 | ||
| conductivity | Advanced Physics Homework | 4 | ||
