Tripling the Distance between Bright Fringes
  • Thread starter Thread starter jst
    Fringes
The discussion revolves around a physics problem involving interference patterns created by light passing through two slits. Participants are examining how to calculate the width of a screen needed for specific bright fringe orders and exploring the effects of changing certain parameters on the distances between these fringes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the appropriate equations to use for calculating fringe distances and the implications of changing parameters like slit separation and wavelength. Questions arise about the correct order of fringes to consider and how to interpret the problem statements.
There is ongoing exploration of the mathematical relationships involved in the problems. Some participants have offered guidance on which equations to apply, while others are questioning their interpretations of the problems and the implications of their calculations. Multiple interpretations of the questions are being considered.
Participants are working under the constraints of specific homework problems, which include given values for wavelength, slit separation, and distances to the screen. There is also a focus on ensuring that calculations align with the expected answers provided in the problems.
jst
A board has two small slits separated by a small distance d. A light ray of a certain wavelength is shone through the holes. A screen is placed in front of the holes and bright fringes are displayed on it. If the light wavelength is 440 nm, the distance between the slits is 4000 nm and the distance between the slits and screen is one meter then how wide would the screen have to be so that the third order fringes just hit its left and right sides?
possible answers
128 cm
14.2 cm
17.5 cm
66.0 cm
38.3 cm
m*LAMBDA = d * y/L
The equation that wrote is the one that I think that I should use, but I am stuck.
A board has two small slits separated by a small distance d. A light ray of a certain wavelength is shone through the holes. A screen is placed in front of the holes and bright fringes are displayed on it. Which of these actions would triple the distance between the zero order and first order bright fringes on the screen?
possible answers
triple the distance between the slits
triple the distance between the slits and screen
double the distance between the slits
double the distance between the slits and screen
double the wavelength of the light
I could figure this one out if I knew the equation used
You have the right equation. Why are you stuck?
In the first question I posted, the part that says: "how wide would the screen have to be so that the third order fringes just hit its left and right sides?"
wavelength = 440nm
m = 2
d = 4000nm
L = 1 m
solve for y?
Yes, solve for y. But you want m=3, don't you?
Yep...my mistake :D
On my 2nd question...does it use the same equation? If so, "triple the distance" is that referring to d or L?
I think you would use the same equation. In the question, triple the distance refers to y, the distance on the screen between the zero order and first order bright fringes.
Thanks a lot...all your help is appreciated...this is what happens when you take physics as an online course :D
You're welcome. Good luck with your course. :smile:
One problem, when I do:
3 * 440 = 4000* (y/1000000000)
y = 3.3E8 nm
= 33cm
Which doesn't match any of the possible solutions, sort of close to one of them, but not close enough to where I would go ahead and select it.
Anything stand out?
The question asks for the width for the third order fringes, so technically that would be from m=-3 to m=+3. (double your answer, basically)
:D I didn't see that..thanks!
On the second problem, I'm thinking: "triple the distance between the slits"
My reason is:
m*LAMBDA = d * y/L
m*LAMBDA = d * 3y/L
y = (1/3) * (LAMBDA * m * L)/d
on the right track?
I have one more similar problem:
A board has two small slits separated by a small distance d. A light ray of a certain wavelength is shone through the holes. A screen is placed in front of the holes and bright fringes are displayed on it. If the light wavelength is 656 nm, the distance between the slits is 4000 nm and the distance between the slits and screen is one meter then what is the distance y in the diagram?
http://glomawr.com/mc006-1.jpg
possible answers
5.20 cm
7.01 cm
32.8 cm
15.7 cm
24.3 cm
I want to put 32.8cm
because of
2*656 = 4000 * (y/1000000000)
y = 32.8cm
but that doesn't seem correct, because of the diagram. Is y (in the diagram) half of a distance or a distance doubled?
For some reason my last post posted several times...not sure...I did hit refresh on the forum, but not the posting.
My reason is:
m*LAMBDA = d * y/L
m*LAMBDA = d * 3y/L
on the right track?
It wants to know what will triple the distance. What you did makes it one third.
possible answers
5.20 cm
7.01 cm
32.8 cm
15.7 cm
24.3 cm
because of
y = 32.8cm
I interpret y in the diagram as from the zero order (centre) to m=2. So I would say your answer is correct.
