Gravitation force caused by uniform rod
joex444
What is the gravitational force caused by a thin uniform rod of length L on a point mass located perpendicular to the rod at it's center? Assume the point mass is a distance R perpendicular to the rod.
g = - \frac{GM}{r^2}\hat{r} = - G\rho \int \frac{dV}{r^2}\hat{r}
g = -G\rho \int \frac{Rdx}{\sqrt{x^2+R^2}^3}
x = Rtan(\phi)
g = -\frac{G\rho}{R} * ( \frac{x}{\sqrt{x^2+R^2}} )
Using limits of integration from -L/2 to +L/2 to yield:
g=-\frac{2G\rho}{R}*(L/\sqrt{L^2+4d^2}) after removing a factor of 4 from the (L/2)^2 from the square root.
Since the y components cancel, I took theta to be the angle nearest the point mass, and called rhat cos(theta) which I evaluated to R/sqrt(x^2+R^2) which could combine with the r^2 in the denominator from the gravity equation.
If this is wrong, I'll be glad to provide more steps to see where I went wrong. I ended up with a 1/(x^2+R^2)^(3/2) in the integral, so I did a trig substition to integrate it, and came up with the formula wikipedia has in its irrational integrals table, so I'm pretty sure that's alright, but wasn't sure if I set it up right.
Looks okay to me. This is how I did it (I get the same integrand form)
d\vec{f} = \frac{Gdm}{R^2+x^2}\left(-\cos\theta \hat{i} + \sin\theta \hat{j}\right)
where
\cos\theta = \frac{R}{\sqrt{R^2+x^2}}
\sin\theta = \frac{x}{\sqrt{R^2+x^2}}
The integrand over \hat{i} is an odd, so it integrates to zero (x ranges from -L/2 to L/2). You get
\vec{f} = -\hat{j}G\lambda R\int_{-L/2}^{L/2}\frac{1}{(x^2+R^2)^{3/2}}dx
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
