| Thread Closed |
Skew & Kurtosis: Weighting Signficance |
Share Thread | Thread Tools |
| May20-07, 05:48 PM | #1 |
Hello everyone. This is my first post to the forum and I'm pleased to be a member.
ISSUE I have various samples, 97 in all, and they are of different sample sizes (n4...n100). All of these samples come from the same population data. The distribution of the population data is NOT normal. Although the population data is not normally distributed, I want to determine which of these 97 samples is closest to representing a normal distribution. I have calcuated the skew & kurtosis for each sample. I then squared the results to make each value of skew & kurtosis a positive number, and then I ranked the skew from smallest to largest and I did the same for the kurtosis. I concluded that the sample with the smallest squared skew and the smallest squared kurtosis best represents the sample that most closely approximates a normal distribution. Something tells me, however, that this ranking system is inadequate because a skew of .01 where sample size equals 9 seems less significant than a skew of .07 where the sample size equals 66. Similarly, a kurtosis of 0 where sample size equals 12 seems like it might be less significant than where kurtosis is .09 and sample size equals 40. Obviously, I'd like to come up with a way to rank the skew and kurtosis of each sample by weighting them somehow. How would you go about weighting them to determine which sample is the best relative representation of a normal distribution? Thank you in advance. Kimberley |
| May20-07, 08:16 PM | #2 |
Recognitions:
| May20-07, 10:59 PM | #3 |
EnumaElish et als.,
Thank you. This is precisely what I was looking for and I really like the JB Test because it combines skew, kurtosis and sample size all into one. I PM'd EE with some follow-up, but thought it best to post it here as well for ease of response and edification. While the JB Test is clearly what I was looking for, I am a bit unclear on the forumla and want to shore up my understanding. 1. Am I correct that a lower JB statistic (e.g., .14) indicates greater relative normality for a sample than a JB statistic of (e.g., 1.7) for another sample? 2. If the answer to 1. is "Yes", and the first part of the formula places your sample size as the numerator over 6, doesn't this penalize larger sample sizes? In other words, if your sample size is n=100, the first part of the equation is 100/6 whereas a sample size of n=20 would only be 20/6, almost guaranteeing that n=20 is going to have a lower JB statistic as compared to n=100. 3. Is S^2 in the formula simply the Skew of each sample size squared?--abundance of caution here (please excuse the poli sci background). 4. MOST SIGNIFICANTLY, in the part of the formula, (K-3)^2/4, don't most basic spreadsheet calculators like MS Excel and OpenOffice already account for the -3 when calculating Kurtosis and, therefore, the -3 is redundant? If so, shouldn't that part of the formula simply be K^2/4? Thank you in advance for any further guidance that you can give me. Kimberley |
| May21-07, 08:37 AM | #4 |
Recognitions:
Skew & Kurtosis: Weighting SignficanceNote this is an asymptotic test, so there is already the assumption that the test is more reliable with large samples. See also: these tests. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Skew & Kurtosis: Weighting Signficance
| Skewness or Kurtosis Problem? | Set Theory, Logic, Probability, Statistics | 1 | ||
| cross section weighting | High Energy, Nuclear, Particle Physics | 0 | ||
| would measures like skewness or kurtosis magnify uncertainty? | Set Theory, Logic, Probability, Statistics | 11 | ||
| the kurtosis of standard normal pdf | Calculus | 1 | ||
| GPA Weighting at UF and FSU | Academic Guidance | 3 | ||
