Uncovering the Metric Sign in Einstein's Equations
  • Context: Graduate
  • Thread starter Thread starter blumfeld0
    Metric Sign
The discussion centers on the necessity of the metric signature in Einstein's equations, specifically the (+,-,-,-) or (-,+,+,+) conventions. This distinction arises from the principles of Special Relativity (SR), particularly the invariance of the speed of light across inertial frames, as established by Minkowski's spacetime interval equation: ds² = dt² - (dx² + dy² + dz²). The signature difference is essential for maintaining the mathematical consistency of General Relativity (GR) when modeling spacetime as a Riemannian manifold, where the local flatness property allows for the diagonalization of the metric at any point.
  • Understanding of Special Relativity (SR) principles
  • Familiarity with Minkowski spacetime and spacetime intervals
  • Knowledge of General Relativity (GR) and Riemannian manifolds
  • Basic grasp of coordinate transformations and Lorentz transformations
  • Study the implications of the Minkowski spacetime interval in various physical scenarios
  • Explore the mathematical foundations of Riemannian geometry in General Relativity
  • Investigate the role of local flatness in the context of curved spacetime
  • Examine the derivation of the Einstein field equations and their applications
Physicists, mathematicians, and students of theoretical physics seeking a deeper understanding of the mathematical structure of spacetime in both Special and General Relativity.
blumfeld0
hi.
1. Why does the sign of the metric have to be (+,-,-,-) or (-,+,+,+)?
meaning why does the sign in front of the time part of the metric have to be different than the signs in front of the spatial part of the metric?
is there a good answer for this question other than it gives the right answer.
2. are the signs something that just pop out after solving the Einstein Equations for various scenarios and doing the math or is it put there ad hoc?
thank you
Einstein derived from a few postulates (most notably that the speed of light is constant in any inertial coordinate system) and logical reasoning the coordinate transformations between two inertial coordinate systems (also known as Lorentz transformations).
Minkowski was the one that realized those transformations conserve the following combination called spacetime interval:
ds^2 = dt^2 - (dx^2 + dy^2 + dz^2) (units of c=1)
That fixed the metric in SR to (+, -, -, -) or (-, +, +, +) depending on the sign convention. SR is GR of the flat Minkowski spacetime.
GR models spacetime mathematically with a Riemannian manifold. Every such manifold has the property of local flatness, i.e. the metric at any point in spacetime can be diagonalized with a suitable coordinate transformation. The resulting local diagonal metric is used by an observer at that spacetime point to measure events around him/her. GR postulates that the diagonalized metric at any point is the SR metric thus the signature of the metric in GR is imported from SR.
The bottom line is that the sign difference between dt^2 and dr^2 originates in the Einstein's SR postulate that light speed is the same in all inertial coordinate systems. If you have a light signal connecting two events separated by dt and dr then according to the SR postulate c=1=dr/dt in any innertial coordinate system. That leads to ds^2 = dt^2 - dr^2 = 0 =invariant (light travels along null paths) which is generalized to nonzero ds^2 for other possible paths not followed by light.
  • · Replies 19 ·
  • · Replies 31 ·
