Can I Find the Height of My Chimney Without Using Expensive Equipment?
  • Thread starter Thread starter Bernie Hunt
    Real world Trig
The discussion revolves around finding the height of a chimney without using expensive equipment. Participants explore practical methods for measuring height, particularly in relation to attaching an antenna and ensuring compliance with local regulations.
  • One participant suggests using trigonometry to calculate the height based on the distance from the chimney and the angle of elevation.
  • Another participant proposes making a simple clinometer as a low-cost solution for measuring angles.
  • Bernie reports a measurement of 23.25 feet using a framing square, indicating a practical application of the suggested methods.
  • A different participant expresses concerns about the structural integrity of chimneys when attaching antennas, citing personal experience with deterioration and failure.
  • This participant also advises considering a roof mount instead of using the chimney for antenna installation.
Participants present multiple approaches to measuring the chimney height, but there is no consensus on the best method or the suitability of using the chimney for antenna installation. Concerns about chimney integrity and alternative mounting options are also raised, indicating differing views on the practicality of the proposed solutions.
Participants mention various assumptions regarding the condition of the chimney and the need for structural support when attaching antennas, but these factors remain unresolved in the discussion.
Individuals interested in DIY measurement techniques, homeowners considering antenna installation, and those concerned about chimney safety may find this discussion relevant.
Bernie Hunt
This may be off topic, but a lot of smart and practical people hang out here so maybe someone can help.
I need to find the height of my chimny in my back yard. I'm not wild about heights, so I'd rather not get out a long tape measure and a longer ladder to climb to the top.
All the word problems we did in high school trig gave us all the pieces. Let's say I find a point 20 feet from the base, the 20*tan(x) where x is the angle to the top, is the answer.
How can I find the angle x, without purchasing some expensive surveying equipment?
Is there a better way to find the height?
The application is how height of an antenna I can attach to my chimney. The town says 40', so I need to know how high it is now, so I know how much mast to purchase. Also, when the inspector shows up, I need to prove that is isn't over 40 feet.
Thanks,
Bernie
Excellent idea. I used a framing square from the shop and got 23.25 feet.
Thanks!
Bernie
I'm a little leery of attaching antennas to chimneys.
Chimneys deteriorate after a while.
In any event, I had a rather expensive antenna AND the top of the double flue chimney hit the pavement after 5 years or so.
The chimney itself was more like 25-30 years and looked fine when I put it up, but if you have any cracks in the top cap they go quickly after that.
The mast on this was only about 4 or 5 feet, with the big antenna around 18" with a small one at the top.
If you are going to 40' then you need to guy the mast, which means the chimney needs to be centrally located.
Personally, I'd forget the chimney and go with a roof mount.
  • · Replies 59 ·
9K
