Dppler and photoelectric effect
The discussion revolves around the Doppler effect and the photoelectric effect, particularly in the context of astrophysics. Participants explore how the Doppler effect influences the energy of photons emitted by celestial objects and the implications for detecting and analyzing light from these sources.
  • Some participants question how the energy of photons changes when celestial objects move away from Earth, particularly in relation to the required frequency for inducing current in devices.
  • There is a discussion about the distinction between normal Doppler shifts and relativistic shifts, with some suggesting that the relativistic effects can be identified by comparing observed frequencies to expected frequencies based on known materials.
  • One participant asserts that energy depends on the reference system, suggesting that photons from a receding source would not have sufficient energy to induce current if their observed frequency is lower than a specified threshold.
  • Concerns are raised about the inability to determine the original frequency of photons, leading to the necessity of using additional information about the source to make inferences.
  • Another participant elaborates on the role of the Lorentz transformation in understanding energy changes at relativistic speeds and emphasizes the importance of accounting for universal expansion in spectral analyses.
Participants express differing views on the implications of the Doppler effect and the ability to determine original frequencies of light sources. There is no consensus on how these factors influence the energy of photons or the methods used to analyze them.
Some limitations include the dependence on definitions of frequency (observed vs. actual) and the unresolved nature of how universal expansion affects photon energy over vast distances.
Will
Doppler and photoelectric effect
When using the doppler effect equations to determine the speed of celestial objects, what happens to the energy of the photons? If a certain device required a 600nm wavelenth of light and frequency 5E14 Hz to induce current, would photons from a celestial body moving away from Earth and emitting this wavelength have sufficient energy to induce current, since observed f is less than 5E14 Hz and E=hf ?
I was curious as to how astrophysicists can distinguish between one lightsource traveling at v1 with frequency f1 and another with v2,f2 if the observed f is the same for both.
Greetings !
There are two types of shifts for light.
One is normal doppler and the other is
relativistic. The relativistic can only
be distinguished by comparing the
frequency to the one we would expect in
this case (based on expected materials,
compared atomic/molecular emmision lines
and so on). The normal doppler effect
is distinguished by comparing the energy
of the photon according to E = h * frequency
(the signs/smilies menu doesn't work for me,
sorry) to the actual reception frequency.
Live long and prosper.
Originally posted by drag
Greetings !
So the energy equation uses what frequency, actual or observed?
The actual frequency is the observed frequency.
They would not. Energy depends on reference system.
Say, water will turn turbine falling from 100 m elevation, but it's energy vanishes if you place turbine at zero elevation and becomes negative if you move turbine higher. Bullet energy becomes zero in the co-moving with the bullet reference system.
They can't. There is no way of figuring out "original" frequency of passing photon. Thus, they have to use additional information (say, about nature of source). For example, scientists are not exactly sure what was original temperature of CMBR when it was emitted. All they know is that at temperatures about T<(3-5)x1000 K hydrogen becomes transparent to radiation (with temperature T), so thery assume that this was the temperature of radiation (thus, of universe) at time of decoupling of CMBR from matter (hydrogen).
Greetings !
Will, I'm terribly sorry !
I was somewhat confused myself and now
I apparently transferred my confusion to you.
But, as long as I admit my mistake and
fix it now, all is not lost ! :smile:
Anyway, The normal Doppler effect for light
is the same as for sound. As the source
moves towards/away from you the frequency of
the photons (EM waves) increases/decreases.
Now, when you "add" relativity you must
also use the Lorentz transformation.
The energy of a photon from such a source
will be higher for you than it is
for the source (in terms of the Lorentz
transformation at least).
Now, the Lorenz transformation only really
comes into play when the source is moving at
relativistic velocities. So, the normal
doppler shift is more significant before
you get to velocities close to the speed
of light (0.8 c +). What's important is that
the relativistic energy and hence frequency
increase of the photon occurs in any case -
no matter whether the source moves towards or
away from you.
The doppler shift is v/c.
The Lorentz transformation is 1/ sqrt(1 - sqr(v / c)).
How is the actual frequency discovered ?
Like I mentioned above it is done by comparing
spectral lines and looking for matches for the
type of materials and energy of reactions you
expect to be present at the source.
Fopr example, one well known frequency is
1.420 Gigahertz (hydrogen - which is abundant
in space - 90% of all normal matter) and it's
frequency shift from a the source can be used
to set the whole spectrum "right".
Another issue worth mentioning is the Universal
expansion. basically if you consider that
the Universe expands by about 65 km per Mega Parsec
per second then the photons traveling from the
source to you will also expand according to
the amount of time it took'em to reach you
(their frequency will decrease).
So, you have to account for that in your
calculations and spectral analyses of distant,
in astronomical terms, sources. Alternatively, this
can also be used to make a general estimate of
distance to the source.
Hope I helped this time. :wink:
  • · Replies 16 ·
  • · Replies 17 ·
