Sketch of curves defined by parameters
The discussion centers on sketching the curve defined by the parametric equation r(t) = (sin(t), cos(t)) for 0 ≤ t ≤ 2π. It highlights that this representation uses polar coordinates, where sin(t) and cos(t) correspond to the x and y coordinates, respectively. The curve describes a circle, as indicated by the equation x² + y² = 1. There's a clarification that in this context, t represents the angle from the positive y-axis rather than the x-axis. For those unfamiliar with polar graphs, converting to Cartesian coordinates is suggested for easier visualization.
smoothman
silly question. didnt know where it was meant to go so i just put it here as safest option:)
suppose a curve C is defined by, r(t) = (sint, cost) with 0 \leq t \leq 2\pi
if a sketch of C was required then would you simply just draw the graphs for sint and cost?
Mathematics news on Phys.org
Based on the equation, it's appears that polar coordinates are being used, where r is the length of the vector, and t is the angle of the vector from the x axis. Sin(t) and Cos(t) are the x and y coordinates of the polar vector. This is a single graph, not two.
If r(t)=(sint, cost) then x component is sint, y component is cost
which means
x^2+y^2=1 as you know it is a circle
but t is not an angle of the vector from x axis( it is valid for (cost,sint))
For our curve if we take t=0 , we obtain the pt (0,1) which is on the y axis
Therefore in our case t is angle from +y -axis
Not sure but this type of questions are generally discussed at homework section
Just thought that a good idea in order to graph the curve C which you have, as Jeff said, written in polar coords. ,if you do not see of-hand how to graph it, would be to switch back (if/where possible) between polars, to Cartesian coordinates, which are the coordinates I think most people are familiar with in terms of doing graphs.
The coordinate change is given by:
x=rcost
y=rsint
and the inverse maps.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
