New Reply
Why do accelerated charges emits a photon?
Share Thread Thread Tools
Sep5-07, 05:38 AM   #1
Question
Is it only when the acceleration is negative? If yes, when it is positive it absorbs a photon?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Sep5-07, 06:09 AM   #2
Recognitions:
Perhaps you should first understand why classical (not quantum) charge emits electromagnetic radiation.
Sep5-07, 07:27 AM   #3
Mentor
This thread has been moved from QM sub-forum to the classical physics sub-forum. I agree that the OP needs to first understand this from the classical E&M perspective.
Zz.
Sep10-07, 12:39 AM   #4
Recognitions:
Homework Helper Homework Help
This is an important question and, remarkably, one that has no definitive answer as far as I can tell.
A charged particle that is accelerated by gravity does not emit an em wave/photon. The only other way to accelerate a charged particle is to apply a mechanical or electro-magnetic force to it over some distance. And a mechanical force is nothing but an em force. Thus, the observational evidence amounts to:
a charged particle does not emit an electro-magnetic wave or photon except when it receives electro-magnetic energy.
So this leads to a reformulation of the question: does the charged particle emit a photon because it accelerates? Or does it emit a photon in response to receiving a photon, which incidentally causes it to accelerate?
The question seems to be still unresolved: See this site, for example.
AM
Sep10-07, 02:02 AM   #5
Recognitions:
Quote by Andrew Mason View Post
This very cute problem is addressed to some extent by Peierls in his little book "Surprises in Theoretical Physics".
Sep10-07, 05:48 PM   #6
What is your basis for that assertion?
Sep10-07, 07:06 PM   #7
Recognitions:
Quote by lugita15 View Post
Apparently, the principle of equivalence...
Consider a man standing on a scale on earth. The scale reads, say, 170 pounds.
Consider a man in completely empty space in a rocketship accelerating at 9.8m/s^2. The man is standing on a scale. The scale reads 170 pounds.
Now, consider the exact same situation but now with a point charge stapled to the man's nose.
If the principle of equivalence holds then... well, shouldn't the stationary point charge in a gravitational field be radiating? Regardless of whether or not it "should", it does not.
Sep11-07, 11:40 AM   #8
Recognitions:
Further to what olegranpappy has said, according to the principle of equivalence, a charged particle accelerating in freefall in a gravitational field is locally equivalent to a charged particle at rest in an inertial frame of reference. Since a charged particle at rest in an inertial frame does not radiate, the same must hold true for the charged particle in freefall. This is consistent with all observation.
A charged particle that is stationary in a gravitional field is locally equivalent to a charged particle accelerating in a gravity-free space. So it should radiate. This is a bit of a problem, because as olegranpappy points out, it is not observed. Here is a paper that explains why this occurs - it suggests that the radiation is a relative phenomenon that depends on the relative acceleration between the observer and the charge:
Quote by From "Radiation from a Charge in a Gravitational Field", Harpaz and Soker
It is found that the “naive” conclusion from the principle of equivalence - that a freely falling charge does not radiate, and a charge supported at rest in a gravitational field does radiate - is a correct conclusion, and one should look for rdiation whenever a relative acceleration exists between an electric charge and its electric field. The electric field which falls freely in the gravitational field is accelerated relative to the static charge. The field is curved, and the work done in overcoming the stress force created in the curved field, is the source of the energy carried by the radiation. This work is done by the gravitational field on the electric field, and the energy carried by the radiation is created in the expence of the gravitational energy of the system.
AM
Sep11-07, 05:33 PM   #9
AM
But I thought that principle of equivalence contradicts special relativity, and by consequence, classical electromagnetic theory as well.
Sep11-07, 05:40 PM   #10
Recognitions:
Hopefully not too much, since special relativity and classical electromagnetic theory are correct.
Sep11-07, 06:17 PM   #11
Recognitions:
The General Theory and the Special Theory of Relativity are perfectly consistent. The principle of equivalence is the cornerstone of GR. Maxwell's equations are consistent with both - certainly with SR. In fact, the belief that Maxwell's equations are valid in all inertial frames of reference was one of the things that drove Einstein to develop SR.
AM
Sep11-07, 10:14 PM   #12
Recognitions:
I should have added after: "So it should radiate"... "IF accelerating charges radiate because they are accelerating.
AM
Sep12-07, 02:02 PM   #13
Recognitions:
Oh, I finally found that book I was talking about earlier. Here's some highlights:
Although the formula for the rate at which a small object loses energy via radiation is
[tex]
\frac{dW}{dt}=\frac{2e^2}{3c^3}a^2
[/tex]
where a is acceleration. And this gives the right answer for total loss. It can not be the right expression for instantaneous rate of loss of energy.
blah blah blah. For periodic or other types of motion we can use instead the expression
[tex]
\frac{dW}{dt}=\frac{-2e^2}{3c^2}v\dot a
[/tex]
where v is velocity and [tex]\dot a[/tex] is "jerk".
Unfortunately, further thought shows that this rewriting does not resolve the paradox... actually, it gets a bit complicated. A careful discussion was given by Rohrlich and Fulton in Ann. Phys. 9, 499 (1960). But the paradox was not truly resolved until arguments by D. Boulware came along (unpublished as of 1979, but given by Peierls in his book).
Sep12-07, 05:52 PM   #14
Hi,
I was reading this thread and I have an additional question to ask. If an electron and a proton were accelerating at the same rate, would they emit the same photon?
Sep13-07, 08:40 AM   #15
Recognitions:
Quote by idea2000 View Post
Hi,
The force on, or rate of momentum change of, the proton would be 1800 times greater than that for the electron. This means that the electromagnetic interaction needed to cause this (ie. the momentum of the photon) would have to be 1800 times greater.
AM
Sep13-07, 06:55 PM   #16
So, it would take really high frequencies of light to accelerate a proton? And would the proton re-emit this frequency of light as well?
A related question:
If we were to accelerate a proton using a very weak magnetic field, would it emit radiation?
Sep13-07, 07:27 PM   #17
You're saying that if an apparatus stands stationary to the Earth, it can not detect radiation from co-supported charges (this much seems sensible, else where would the energy come from: no other part of the system has given up change). But just to clarify:
If a charge is released to fall freely past the apparatus (and vice-versa), is radiation then detected? If the apparatus is placed on (say) an accelerating train, will it continue not to detect radiation from co-accelerated charges?
Actually, my understanding was that the field lines of a constantly accelerated charge merely "droop". This isn't radiation if you can stay stationary with respect to charge and the direction of acceleration. I think the equivalence principle here is unscathed (until you add boundary conditions, but that feels like cheating).
New Reply
Thread Tools
Similar Threads for: Why do accelerated charges emits a photon?
Thread Forum Replies
Compton scattering: electron absorbs then emits a photon? Quantum Physics 13
Raman Scattering - what emits the photon? Advanced Physics Homework 8
Accelerated charges radiate energy Introductory Physics Homework 1
Accelerated charges loose energy Special & General Relativity 2
why do accelerated charges emit e/m radiation? General Physics 1
