Is Richard Robinett's Fourier Transform Convention Unconventional?
ehrenfest
Richard Robinett defined the Fourier transform with an exp(-ikx) and the inverse Fourier transform with an exp(ikx). I have always seen the opposite convention and I thought it was not even a convention but a necessity to do it the other in order to apply it to some Gaussian equations. Has anyone ever seen this sign convention before?
It really isn't relevant whether it's with a plus, or with a minus. I've seen in most cases
\phi (x)=\frac{1}{(2\pi)^{3/2}}\int dk \ \tilde{\phi}(k) e^{-ikx}.
Note that the integration is from -\infty to \infty. That's why the sign does not matter.
Furthermore, the constants in front also do not really matter, as long as they combine to give 1/(2 pi). There are a couple of theorems which depend on them (I think Parseval's theorem and the associated ones do), but it's all up to a constant. My supervisor (in physics) recommends just ignoring the constants, and adding them back in if you have to at the end :wink:
If you define the Fourier transform as dextercioby did:
\phi (x)=\frac{1}{(2\pi)^{3/2}}\int dk \phi(k) e^{-ikx}
then the inverse transform is:
\phi (k)=\frac{1}{(2\pi)^{3/2}}\int dx \phi(x) e^{ikx}
It is merely a matter of convention which is called which. There's no 'wrong' convention as long as you remain consistent.
On page 11 of 'Photons and Atoms' by Claude Cohen-Tannoudji et. al. the convention above is used. On page 97 of 'The Principles of QM' by P.A.M. Dirac, the convention is left deliciously ambiguous.
Dirac said:
These formulas have elementary significance. They show that either of the representations is given, apart from numerical coefficients, by the amplitudes of the Fourier components of the other.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
