After what time interval does the ball strike the ground
A ball is thrown downward from a height of 30m with an initial speed of 8m/s, and the acceleration due to gravity is -9.8m/s². To determine the time it takes for the ball to strike the ground, the appropriate equation is Yf = Yi + Vi(t) + 1/2g(t²), while ensuring the correct signs for direction are used. The discussion also briefly touches on a separate problem involving a horse moving at 10m/s, but confusion arises regarding the context of the "limb" referenced. The recommended approach for the horse's problem is to use a distance formula, as time is not provided but distance is. Overall, clarity in problem statements is emphasized to avoid confusion in calculations.
012435
A ball is thrown downward with initial speed of 8m/s from a height of 30m.
\After what time interval does the ball strike the ground
acceleration will equal -9.8m/s^2 because it's free fall
would i use equation V=Vo-gt
constant speed of a horse is 10m/s. distance from limb to saddle is 3m
A) find horizontal distance between saddle and limb?
B) for what time interval is he in the air?
Attempted solution:
X=Xo+Vo(t)+V2(a)(t^2)
what equation do you use to find the time ... Yf=Yi+Vi(t)+1/2g(t^2) and rearange it to
I'm confused. There seems to be two questions... one about a ball... about about a horse and saddle?
sorry. it's two different problems
This is the right equation to use for the first problem:
but you need to be careful about directions and signs... you've taken downwards as positive here...
Since you are NOT given the time but ARE given a distance, it would be better to use a distance formula: d= (1/2)gt2+ v0t. Donht forget that v0 is negative.
Attempted solution:
This makes no sense to me at all. What does the "distance from saddle to limb" . At some paces some horses can go 10m/s while always having at least one foot on the ground- they are never "in the air".
And what "limb"? A foreleg? Or is this a limb of a tree? Did you leave something out? is the horse jumping over a limb?
yea i would use this formula
