2 particles moving along x axis.
  • Thread starter Thread starter ~christina~
    Axis Particles
Two particles are analyzed for their motion along the x-axis, with particle 1's position defined by a quadratic equation and particle 2's acceleration given as a function of time. The discussion includes plotting their velocities and accelerations, determining if either particle is instantaneously at rest within a specified time frame, and evaluating the applicability of uniform acceleration motion (UAM) equations for particle 2. The calculations reveal that particle 1 maintains constant upward motion, while particle 2 levels off, indicating it is momentarily at rest. The conversation emphasizes the importance of integrating acceleration to find velocity and clarifies the relationship between units of measurement in physics.
~christina~
[SOLVED] 2 particles moving along x axis.
Two particles move along the x axis. The position of particle 1 is given by
x= (6.00m/s^2)t^2 + (3.0m/s)t + 2.00m
the acceleration of particle 2 is given by:
a = - (8.00 m / s^3) t and, at t = 0, its velocity is 20 m / s.
(a) Plot the velocities of the two particles versus time on a single graph.
(b) Is either of the particles instantaneously at rest between t = 0 and t = 3s?
(c) If the answer to
(b) is yes, then name the particle(s) and the time(s).
(d) Can the UAM equations be used to describe the motion of particle 2? Use the correct physics principles to support your response.
(e) Plot the accelerations of the two particles versus time on a single graph for the time interval given above.
a = - (8.00 m / s3) t and, at t = 0, its velocity is 20 m / s.
I want to check my thinking first of all since this a long problem.
Do I have to get the derivative of the equation of the equation given?
and what do I do with the values given for particle b?
How do I put them together to graph it??
for d.) what is a UAM equation?
~Thanks~
1. yes, for the velocities.
2. with the values given for the second particle you can find by integration the velocity of the body.
3.well the equations for velcoities give you the answer how.
4.im not sure about UAM, but perhaps it's uninform acceleration movement, although from the given you can see that the accleration isn't unifrom cause it changes with time.
You are given x(t) for particle 1, and a(t) and v(0) for particle two. You need to figure out v(t) and a(t) for both. So, for particle 1 how do you get v(t) from x(t), and then a(t) from v(t)? For particle 2, how do you get v(t) from a(t) and v(0)?
Is this alright?
for particle 1 :
v'= x(t)dx/dt = (6.00m/s^2)t^2 + (3.00m/s)t + 2.00m= (12m/s^2)*t + 3.0m/s
particle 2:
a= -(8.00m/s^3)t
v=\int a(t)= \int -(8.00m/s^3)t= -(4.00m/s)t^2 + t
~I don't get why they say that when t= 0 v= 20m/s for particle 2 since if I plug it into a equation it doesn't equal 20m/s
a.) well if I graph that direclty wouldn't it be wrong since they say the particle is moving at 20m/s at t= 0 ?
b.) For this part of the problem I don't know how to see whether the particles are instantaneously at rest since I put the equations into my calculator and saw that the first one is a parabola but the top flat part starts out at 0 and encompases quadrants 3 and 4. The other one is a straight line that starts in quadrant 3 and goes through quadrant 2.
~ I also don't know how to get the equation specifically for the velocity for both since they include units and I'm not sure how m/s => ? when derived or vice versa since I've always just worked with numbers and not actual units and the units were plugged in at the end.
Help..~Thanks~
first of all accleration is measured by meters per seconds^2.
now i see you don't know how to integrate, the indefinite integral of t wrt t is: t^2/2+c where c is a constant, form you are given you get v_2(t)=-4t^2+c
now if you plug in v_2(0)=-4*0^2+c you get that c=v_2(0) which is 20 and then you replug it to the equation.
So I would get making the correction:
Particle 1: v(t) = x'(t)= x(t)dx/dt = (6.00m/s^2)t^2 + (3.00m/s)t + 2.00m= (12m/s)*t + 3.0m
(I corrected the units for particle 1 as well)
Particle 2: v(t)= \int ax(t) dt=\int - (8.00 m / s^3) t = -(4.00m/s^2)t^2 + 20
The point you make about the acceleration being m/s^2 is something I already know but the question was given by my teacher as s^3 so I'm not sure if it's a typo or not...is velocity ALWAYS m/s^2? b/c that would mean that it's a typo and my v for the second particle would be v(t)= -(4.00m/s)t^2
I did that and they intersect at x= 1.05, y= 15.59
I think that since the first particle is a straight line and keeps going up that it isn't instantaneously at rest at any point. Particle 2 however does level off at the top of the parabola so it would be yes
(c) If the answer to is yes, then name the particle(s) and the time(s).
I say it is particle 2 and the time is at t=20s
You are correct in saying it was the uniform accelerated motion equations but it DOES change with time but I guess but it doesn't count for the instantaneous part of the graph where the v= 0 right?
Wouldn't a/t= J ?
Would I derive the equation of both equations given to get the acceleration for the time interval?
~THANKS~
