Calculate combined apparent magnitude of two stars
In summary, to find the combined apparent magnitude of a binary system consisting of two stars of apparent magnitudes 3.0 and 4.0, you need to convert the magnitudes to intensities using the equation f(n)/f(m)=100^(m-n)/5. Then, add the intensities of the two stars to get the total intensity of the pair. Finally, compare this total intensity to that of a zero-magnitude star to find the magnitude of the pair.
Benzoate
422
What is the combined apparent magnitude o a binary system consisting of two stars of apparent magnitudes 3.0 and 4.0
m-n=2.5 log(f(m)/f(n))
I know m= 3 and n=4 ,or vice versa. I'm not sure what this problem means by combined magnitude. Do they mean I should add m and n together?
Refer to your other post on the magnitude of a variable star for the discussion on the magnitude system.
What you want to do is convert your magnitudes to intensities, since the intensities of the two stars can be added to give the total intensity (or brightness or power) of the pair. This leaves the question of what to use for a basis. You can pick any reference magnitude, say, zero, and compute the intensity of each star relative to the intensity of a zero-magnitude star. You would then add the intensities of each star and now compare the total intensity to that of the zero-mag star to find the magnitude of the pair.
Is the equation for intensity, f(n)/f(m)=100^(m-n)/5. for example , can I tlet my reference magnitude be 0 and magnitude of m(1) is 3 and for the second intensity, reference magnitude n is still zero and magnitude of m(2) is 4. Once i calculated the each of the intensities for the two stars , I proceed to add the two intensities of both stars?
I think your book or instructor is still using f from flux, but yes, that will work. (I just corrected a missing minus sign in my post in the other thread.)
Somehow I got only the first line of this post when I went to reply to it... (?)
Yes, that is what I'm describing. You should get intensities which are between zero and 1, since they are the intensities relative to a brighter star...
1. What is the formula for calculating the combined apparent magnitude of two stars?
The formula for calculating the combined apparent magnitude of two stars is M = -2.5 log10(F1 + F2), where M is the combined apparent magnitude and F1 and F2 are the individual fluxes of the stars.
2. How is the combined apparent magnitude different from the individual magnitudes of the stars?
The combined apparent magnitude takes into account the total amount of light emitted by both stars, while the individual magnitudes only measure the brightness of each star on its own. The combined magnitude may be brighter or dimmer than the individual magnitudes, depending on the relative magnitudes and distances of the stars.
3. Can the combined apparent magnitude of two stars be negative?
Yes, the combined apparent magnitude of two stars can be negative if the combined flux is very large. This would indicate that the stars are very bright and may be close together in the sky.
4. How do I know which flux values to use when calculating the combined apparent magnitude?
The flux values used in the calculation should be the apparent fluxes of the stars, meaning the amount of light that reaches Earth's atmosphere. This can be determined using a telescope and photometer to measure the stars' brightness.
5. Can the combined apparent magnitude be used to determine the distance between the stars?
No, the combined apparent magnitude is not enough information to determine the distance between the stars. Other factors such as the individual distances and relative positions of the stars must also be taken into account.
