Simplify the Equation (m - M) + 5 = 5(log d) for Easy Understanding
  • Thread starter Thread starter Aftermarth
    Rearrange
To isolate d in the equation (m - M) + 5 = 5(log d), the transformation leads to d = 10^(((m - M) + 5) / 5). This calculation assumes the logarithm is base 10, which is standard for this equation related to distance from absolute and apparent magnitude. The confirmation of using base 10 is crucial for accuracy. Overall, the derived formula provides a clear method for calculating distance based on the given magnitudes.
Aftermarth
ok i want d the subject in:
m - M = 5 (log d) - 5
ok now.
((m - M) + 5) / 5 = log d
d = 10 ^ ((m - M) +5) / 5)
is that right?
Yes, assuming the log is base 10.
yes I am pretty sure it is. everything i have seen on the equation (its the equation to work out distance from absolute and apparent magnitude) has nothing other than base 10. so assuming base 10 cool :D
