Thread Closed
Apparent Weight
Share Thread Thread Tools
Nov7-07, 07:29 PM   #1
Apparent Weight
A man with a mass of 85.0 kg rides downward on an elevator.Initially the elevator accelerates downwards at 1.845 m/s^2 and eventually slows at 1.60 m/s^2 as it reaches the ground floor. Find the mans apparent weight as he starts down and as he reaches the ground floor.
2. Relevant equations
fn=m(a-g)
3. The attempt at a solution
fn= (85.0 kg) (1.85m/s^2--9.81m/s^2)
=991.1 N
fn=m(a-g)
= (85.0 kg) (1.60 m/s^2--9.81 m/s^2)
=969.85 N
The question I have is in the second part of the question should th value for a be positive or negative?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov7-07, 07:46 PM   #2
Mentor
This is not quite right: you added instead of subtracted.
It might be clearer if you wrote it as:
[tex]\Sigma F = F_n - mg = ma[/tex]
So:
[tex]F_n = m(a + g)[/tex]
But note that the acceleration is downward and thus negative.
Nov7-07, 08:08 PM   #3
So fn=85.0kg ( -1.85m/s^2 +(-9.81m/s^2)
=-991.1N
fn=85.0kg (-1.60 m/s^2 + (-9.81 m/s^2)
= -969.85N
Is this correct?
Nov7-07, 08:21 PM   #4
Mentor
Apparent Weight
No, you're making the same mistake. In the expression "a + g", it's "a" (the acceleration of the elevator) that is negative, not g! (g is just a positive constant = 9.81 m/s^2.)
Always do a sanity check: If the elevator accelerates upward, you'd be squashed against the floor giving a greater apparent weight; if it accelerates downward, you'd be pulled away from the floor, reducing your apparent weight.
Nov7-07, 09:44 PM   #5
fn =85kg (-1.85 m/s^2 +9.81m/s^2)
= 676 N
fn = 85kg ( 1.6m/s^2 + 9.81m/s^2)
= 969.85 N
Is this correct?
Nov8-07, 05:22 AM   #6
Mentor
Excellent! The wording of the problem was a bit tricky. At first the elevator accelerates downward at a = -1.85 m/s^2. Then it slows down, which means it accelerates upward at +1.6 m/s^2.
Nov8-07, 07:07 AM   #7
Thanks for the help !
Thread Closed
Thread Tools
Similar Threads for: Apparent Weight
Thread Forum Replies
Apparent weight Introductory Physics Homework 2
Apparent Weight Introductory Physics Homework 10
Apparent Weight Introductory Physics Homework 14
apparent weight Introductory Physics Homework 1
