What is the angular speed of a grindstone spinning at 8.3 rev/s?
The discussion centers on calculating the angular speed of a grindstone spinning at 8.3 revolutions per second (rev/s). The formula for angular speed is provided as angular speed = 2π(f), where f represents the frequency in rev/s. Participants express skepticism about the need for a specific book containing this question, suggesting it is a straightforward problem. The search for relevant resources yields limited results, with only three mentions found online. The conversation highlights both the simplicity of the question and the difficulty in locating a specific reference.
ftth
Anyone know a name of a book that has question "A grindstone spinning at the rate of 8.3rev/s has what approximate angular speed?"
Why do you need to find this book? This is a basic question, anyone could have made this up on the fly.
angular speed = 2pi(f)
f = rev/s
Only 3 hits from google -- two from here on the PF, and one from an exam:
http://astro1.panet.utoledo.edu/~dshvydka/Midterm%20Exam%202.htm
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
