| Thread Closed |
[SOLVED] Quadratic Function |
Share Thread | Thread Tools |
| Nov28-07, 08:40 PM | #1 |
solve (f(x)=-3 x^2 + 9 x + 1/4 ) fx=(-3)(x^2-3 x)+1/4 fx=(-3)(x^2-3 x+9/4)+1/4+27/4 fx=(-3)(x^2-3 x+9/4)+28/4 fx=(-3) (x-3/2)^2+7 2. Relevant equations 3. The attempt at a solution the solution is already given in the book, but I don't understand why 9/4 was inserted in the third line (bolded). I know at the end of the equation, 27/4 is added to balance out the 9/4.......but why put in 9/4 there? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov28-07, 08:52 PM | #2 |
What they've done is simply completed the square. If you have an equation of the form: [itex] x^2+2ax [/itex], you can write it as: [itex] x^2+2ax = (x+a)^2 - a^2 [/itex].
| Nov28-07, 10:25 PM | #3 |
Recognitions:
they just put 27/4 and -27/4 to make completion easier f(x)=-3 x^2 + 9 x -27/4+ 1/4 +27/4 =-3(x^2-3x+9/4)+7 =-3(x-3x/2)^2 +7 expand (x-3x/2)^2 and check it yourself |
| Nov28-07, 10:28 PM | #4 |
yea bro...
the thing is, how do you come up with 9/4 from to make it easier? I'm on purplemath.com right now, trying to figure it out without bothering you guys... hopefully I can figure this one out. |
| Nov28-07, 10:36 PM | #5 |
Well heres how I would have done that problem. You're given:
[tex] f(x) = -3x^2 + 9x + \frac{1}{4} [/tex] [tex] f(x) = -3( x^2 -3x) + 1/4 [/tex] Now we notice that the term in brackets is of the form [itex] x^2+2ax [/itex], with [itex]a=\frac{-3}{2}[/itex], and so we complete the square [itex] x^2+2ax = (x+a)^2 - a^2 [/itex]: [tex] f(x) = -3\left(\left(x-\frac{3}{2}\right)^2 - \frac{9}{4} \right) + \frac{1}{4} [/tex] [tex] f(x) = -3\left(x - \frac{3}{2}\right)^2 + \frac{27}{4} + \frac{1}{4} [/tex] [tex] f(x) = -3\left(x - \frac{3}{2}\right)^2 + 7 [/tex] |
| Nov28-07, 10:58 PM | #6 |
okie.........i got it.
so the point of adding -9/4 inside the brackets is so that you can make it factorable. And since you added a (-), now you have to minus it to even it out. thnkx.....can't believe it took me so long. anyhow, how do you type the math out like that? |
| Nov29-07, 02:56 AM | #7 |
You use LaTeX. This tread explains in more detail.
http://www.physicsforums.com/showthread.php?t=8997 |
| Nov29-07, 02:16 PM | #8 |
test:
[tex]x=-3 x^2+9x+1/4[/tex] [tex]fx=(-3)(x^2┤-3 x)+1/4\\[/tex] [tex]fx=(-3)(x^2┤-3 x+9/4)+1/4+27/4\\[/tex] [tex]fx=(-3)(x^2┤-3 x+9/4)+28/4\\[/tex] [tex]fx=(-3) (x┤-3/2)^2+7\\[/tex] |
| Nov29-07, 02:21 PM | #9 |
http://at.org/~cola/tex2img/index.php |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Quadratic Function
| [SOLVED] Quadratic | Precalculus Mathematics Homework | 4 | ||
| [SOLVED] Quadratic Equations and Inequalities question about properties of quadratic | General Math | 2 | ||
| quadratic function | Introductory Physics Homework | 1 | ||
| Quadratic equation and Radical function!!! | General Math | 1 | ||
| quadratic function - x-intercepts? | General Math | 1 | ||
