Transverse Wave Homework Problem
The discussion centers on solving a homework problem involving a transverse wave described by the function y(x, t) = (15.0 cm) cos(πx - 12πt). The main goal is to determine the transverse speed of a point on the string when its displacement is 12.0 cm. Participants emphasize the need to identify the specific point in time and space corresponding to the given displacement before applying the wave equation. The maximum transverse velocity is noted as w*A, where w is the angular frequency and A is the amplitude. The urgency of the situation is highlighted by the mention of an impending final exam.
zjm7290
The function y(x, t) = (15.0 cm) cos(\pix - 12\pit), with x in meters and t in seconds, describes a wave on a taut string. What is the transverse speed for a point on the string at an instant when that point has the displacement y = 12.0 cm?
I know that the equation of the wave is given above and the max transverse velocity is w*A and the max transverse acceleration is w^2*A and I know how to get the velocity of the wave in the x direction (propagation)
I'm not sure where to even start, I think I need to find where 12.0cm is in reference to either distance or time, then I could just plug it into the wave equation, I'm just not sure how to get there. Any help would be greatly appreciated!
please guys! i have a final on this friday! anyone?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
