Thermal conductivity twice that of brass
The thermal conductivity of aluminum is twice that of brass, and the problem involves two rods joined end to end, with one end of the brass rod at 0 degrees C and the aluminum rod heated to 200 degrees C. To find the temperature at the interface, the heat equation is relevant, specifically in a steady-state scenario where no heat escapes from the sides. The relationship between thermal conductivities should be used, with brass's conductivity denoted as k and aluminum's as 2k. The discussion emphasizes the need to establish a temperature gradient and apply the principle of equal heat transfer rates through both rods to solve for the interface temperature.
Dx
Hiya!
The thermal conductivity al Al is twice that of brass. Two rods (1 Al and the other brass) are joined together end to end in excellent thermal contact. The rods are of equal lengths and radii. The free end of the brass rod is maintained at 0 degrees C and the Al free end is heated to 200 degree C. If no heat escapes from the sides of the rods, what is the temperatur at the interface between the two metals.
This sounds somewhat like a difference equation problem and i think i must find the thermal conductivity of Al and brass which i think one is .11 and the other .84 or something, ill have to recheck it. My question is what formula do i use to solve for this?
Thanks!
Dx :wink:
At what time? That bit of information is crucial!
A difference equation? No, you are going to run into a partial differential equation, namely the heat equation.
You know it doesn't say, interesting? It must be a trick question then.
A difference equation? No, you are going to run into a partial differential equation[/i], namely the heat equation.
Your right, a partial.
Thanks!
Dx :wink:
Yes, the heat equation is (for constant conductivity):
cρ∂T/∂t=κ[nab]2T
Since there is a time dependence, we need to know something about that.
Go for the time independent solution. If both ends of the system are held at a constant temp a non time dependent solution will develop.
start with
dQ/dt = - kAdT/dx
A = cross sectional area
k = thermal conductivity
This holds in each material. Further, since no heat is lost from the system, we have dQ1/dt = dQ2/dt, also given in the problem A1 = A2
let dT/dx = (T2 - T1)/L in each material
You need to draw a picture of the sytem, define T1, T2 & T3 for your system, recall that the boundry will be a common point. Assemble the pieces of the puzzel I have presented and do some algebra.
Don't look up the thermal conductivities. In this problem you are given that "the thermal conductivity of Al is twice that of brass" (which is approximately correct) so that is the relationship you should use to solve it (i.e. let k=thermal conductivity of brass and 2k=thermal conductivity of Al).
I don't disagree with Integral, but you may find this easier (it is based on exactly the same approach as Integral's answer):
Assuming that the temperature gradient is uniform,
P (the rate of energy transfer) is proportional to the cross-sectional area A and the temperature difference, and inversely proportional to the length.
k, the thermal conductivity, is the proportionality constant, so (for EACH rod):
P = kA(T2 - T1)/L
Once a steady state is reached, the rate of heat transfer through both rods will be equal.
Using this, you should be able to calculate the steady-state temperature at the interface.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
