Thread Closed
[SOLVED] Same string, different mass per unit length, whats the wavelength?
Share Thread Thread Tools
Feb4-08, 06:45 PM   #1
*oddly I can't edit the original title?
A string is made of two materials of different mass per unit length. On the left side of the string, the mpu is given as well as its wavelength. On the right only the mpu. The question asks for the right side's wavelength.
2. Relevant equations
xxx
3. The attempt at a solution
I immediately began doing just a simple balancing equations. 2.76/20.4 = 3.63X
yet it returned the answer as incorrect. How can that be??
as well, I thought maybe it was trick question since its all the same single string, the wavelength must be the same. so I put 20.4 and as well it returned it as incorrect.
I'm really not sure what I did wrong.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb4-08, 07:05 PM   #2
Mentor
How does the wavelength (or wave speed) depend on the mass per unit length?
Feb4-08, 07:15 PM   #3
Not sure if you were questioning me or you stating the problem variables don't depend on one another.
mu (mpl or mass per unit length) = string mass / string length
v = square root of (T / mu) where t = mg
thats all I can really find or think of regarding mu
Feb4-08, 07:18 PM   #4
Mentor
Quote by bobbo7410 View Post
Good. The square root is key. That's what you were missing earlier.
Feb4-08, 07:31 PM   #5
? earlier all i had was a simply balanced equation thats it.
v = square root (T/mg) T being the period and mg being mass * gravity
I dont know T, or the mass.
perhaps you could break it down a little more basic for me.
Thanks for the help!
Feb4-08, 07:46 PM   #6
Mentor
Your balance equation was incorrect. Come up with a new one using the equation for wave speed.
I thought we agreed that: v = square root (T/mu)
You don't need to know the tension, since it's the same for both sides of string.
Combine this with the "wave equation": v = f * wavelength. (Hint: The frequency is also the same for both sides.)
Feb4-08, 08:02 PM   #7
: ) thank you! that made it much simpler for me, I got it correct.
for some reason I looked back and the mu looked like mg.
So basically:
v = square root (T / mu)
v = f * wavelength
so [ f * wavelength = square root ( T / mu ) ]
I set the frequency to 1 for both so I only had 1 variable to determine. I solved for T on the left side of the string and once I found that I used that same T to determine the wavelength for the right side.
yey thanks doc
Feb4-08, 08:18 PM   #8
http://www.physicsforums.com/showthr...41#post1597041
for my first equation.. Would it be beneficial to use the same setup as above to solve for frequency or T?
because if I were to find either of those I could easily find the velocity. yet I think am back where I started (2 unknown variables) since I can't simply substitute 1 for the frequency in that problem.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Same string, different mass per unit length, whats the wavelength?
Thread Forum Replies
[SOLVED] [Multiple Choice] ...wavelength of an object. de Broglie wavelength Introductory Physics Homework 11
[SOLVED] Finding mass per unit length for stretched strng given tension? Introductory Physics Homework 1
Wavelength and length of wire limitation? General Physics 3
[SOLVED] Mass per Unit Length of Violin Strings Introductory Physics Homework 1
[SOLVED] how is it that the Atomic Mass Unit is less than either the General Physics 5
