Notational problem in tensor calculus
jacobrhcp
Using the Einstein convention, is this about right? (indexes run from 1 to 3):
\nabla\bullet(x_{i}a)=div(x_{i}a)=\partial_{j}a_{j}x_{i}=3x_{i}
The partial derivatives are take wrt what variable ? x or a ?
it's said x above the exercises \partial_{j}=\frac{\partial}{\partial x_{j}}}
and the question is:
calculate explicitly: \nabla \bullet (x_{i}\vec{a}), where a is a constant vector...
my attempt is way off, but I don't feel at home in these new symbols enough to get the right answer.
x_i{\vec a} is not clear notation. Does it mean the i component of a tensor
[xa], or does it mean {\vec\hat i}\cdot{\vec r}{\vec a}?
You are right that it means \partial_{j} (a_{j}x_{i}) But the components of a are constants so this is equal to a_j \partial_{j} x_{i} Now, what does \partial_{j} x_{i}give ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
