Abelian Group; what to do if the set is G=R-{1/3}?
lostinmath08
On the set G=R-{1/3} the following operation is defined:
*G: GxG arrow G
(x,y) arrow x*y=x+y-3xy
Show that (G,*) is an abelian group.
To proove something is an abelian group:
The Associative Law need to hold true x*(y*x)=(x*y)*x
Neutral Element needs to be true e*x=x*e=x for all or any x E G
Inverse Elements x*x'=x'*x=e where x' is called the inverse element of x
Commutativity x*y=y*x
I don't know how to solve this, especially with a set like this. Any Hints or Advice would be greatly appreciated
You posted a problem like this before. Commutativity should be obvious. Try solving for e. Just get started with any property you want to start out with.
I have already solved for the properties, but I thought the set matters.
The set does matter. Because once you have figured out that e=0, then 1/3 is the only element of R that doesn't have an inverse under the operation '*'. So if you include 1/3, it's not a group. Just like R-{0} is a multiplicative group and R isn't.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
